2.25l starter
ssortnarg
2.25l starter
#1 Post by ssortnarg » Sat Mar 25, 2006 8:11 am
we need to remove the starter on our 2.25l 83 11 csw -
the lower bolt is fairly accessable but the upper appears to be obstructed by the heat shields and exhaust manifold
Is ther a trick to accessing the upper bolt , or am I missing the obvious .
Greasy Fingers
#2 Post by Rob » Sat Mar 25, 2006 11:37 am
According to the green bible for series 3 (should be similar for your 2.25) you have to remove the exhaust heat shield and disconnect the exhaust pipe at the manifold.
Hope this helps, Rob
88 RRC
