RRC and Disco 1 Axle Parts, ALL SOLD
jeepingpw
Worm Gear
#1 Post by jeepingpw » Sun May 01, 2022 7:53 am
RANGE ROVER CLASSIC & DISCOVERY 1
Front Axle Parts : ALL PARTS HAVE BEEN SOLD
All Parts Are New In Boxes unless otherwise noted
Prices are same as Craddock Spares prices in Canadian Dollar
You Save the Shipping from England, Import Fees and GST
Check Part Number To Make Sure it Fits Your Vehicle
Pinion Seal, x3 p/n FRC8220 $ 9.00 for 3
Stub Axle Gasket x10 p/n FTC3648 $ 2.50 for 10
Inner Axle Thrust Sleeve, Bronze x2 p/n 571822 $40.00 for 2
Swivel Housing Gasket x2 p/n FTC3646 $ 0.80 for 2
Swivel Pin Gasket, x4 p/n 571815 $ 4.00 for 4
Swivel Housing Oil Seal, BritPart, x2 p/n FTC3401 $10.00 for 2
Swivel Housing Oil Seal, BearMach, x2 p/n BR3213 $ 8.00 for 2
Swivel Seal Retain Ring x2 p/n 571755 $ 9.00 for 2
Hub Seal, Outer x2 p/n FRC8222G $14.00 for 2
Hub Seal, Inner x2 p/n FTC4785G $10.00 for 2sold
Wheel Seals, Inner x2 p/n FTC5268 $ 8.00 for 2
Terrafirma HD Drive Flanges p/n TF859 $50.00 set of 2
Drive Flange Gasket x2 p/n FRC3988 Included with Flanges
TerraFirma HD, Coil Spring Retainerr p/n TF505 $18.00 pr SOLD
TerraFirma HD, Front Shock Turret Rings p/n TF502 $33.00 prSOLD
Poly Sway Bar Bushing, Black p/n NTC6828 $12.00 pr
Caster Correcting Radius Arm Bushing p/n DA8952 $145.00 set
3 Degree, Old Man Emu brand
Front Axle Parts Kits:
Swivel Seal/King Pin Kit, x2 Kits
(1 kit required per side) p/n DA3166P $100.00 for 2 kits
Includes :
Swivel pin bearing
Swivel pin kit - upper – ABS (King Pin)
Gasket
Seals
Plate
Shims
Joint washers
Swivel housing grease sachet
https://i.postimg.cc/TPMyw906/swivle-kit.jpg
Wheel Bearing Kit, x2 Kits
(1 kit required per side) p/n DA2387 $84.00 for 2 Kits
Includes:
Bearing w/Race, Inner & Outer
Oil Seal
Flange Gasket
Flange Bolts
Hub Nut and Washers
Bearing Grease
https://i.postimg.cc/cHT6FNSx/wheel-bearing.jpg
Rear Axle Parts
TerraFirma HD, Coil Spring Retainer, pr p/n TF506 $15.00 pairSOLD
Spring Isolaters , Rubber, pr , p/n ANR2938 $10.00 pair
Poly Sway Bar Bushing, Black, set p/n NTC7394 $15.00 set
