LR4 smoke coming out of A-pillar
Had the exciting discovery of smoke coming out of the passenger side A-pillar about 2 miles from home. Used a T-27 torx to take of the trim and found the connector to the heated windscreen was cooked. Cut the connector off, crimped on a new connector with some shrink tube and all is good.
- (129.72 KiB) Downloaded 54 times
- (87.51 KiB) Downloaded 53 times
- (86.13 KiB) Downloaded 54 times
- (76.34 KiB) Downloaded 53 times
- (92.26 KiB) Downloaded 53 times
