ROTO FLEX
96whitedisco
ROTO FLEX
I was on the island Hiway this weekend and noticed a bad vibration from below, the tires are new and balance the steering wheel had no vibration.
Im thinking its my Roto Flex coupler?
Has anyone out there replaced theres?
Has anyone done the upgrade and removed the Roto flex and put a longer drive shaft with the new longer unjoint?
Andrew
Andrew
JD
Old Island Goat Track
Greg,
Perhaps the OLD Island Hwy? New one's not too bad .... yet.
JD
JD
I have the Rotoflex on my 99 Disco. I was told over a year ago it was a bit worn, but its quite a ways down the list for replacement. I have, however been watching for a used Disco 1 rear driveshaft without the rotoflex, so far, without success.
Suffice it to say, mine does not create any vibration, although its visibly worn. Might want to look at a few other things. Tied rod ends, for example... Often you won't feel it in the steering even if its the front axle, due to the cushioning that the power steering provides.
96whitedisco
96whitedisco
96whitedisco
