Any suggestions where to get this done and/or find a reman one already done?
Thanks.
TD5 exhaust manifold skimming
philchan1974
- Over Inflated
landcrabmechanic
Re: TD5 exhaust manifold skimming
If you take the manifold to any competent machine shop, they will be able to skim it for you.
paulg_d130
i did mine at home on my large belt sander and just used a long stainless steel straight edge (ruler) to check it as I went. use 80 and 120grit belts and it worked quite well.
