Magnacor Plug wires
96whitedisco
Magnacor Plug wires
#1 Post by 96whitedisco » Wed Feb 22, 2006 3:23 pm
Anyone no if theres a dealer for Magnacor plug wires in the Vancouver area?
Checked mopac they were a big help NOT!
Lordco etc etc!
Andrew
Cylinder bore
#2 Post by John » Wed Feb 22, 2006 3:43 pm
Andrew,
You could see what Discotech in North Van have in regards to the decaling
http://www.disco-tech.ca/
I looked for Magnacor a few years ago and ended up ordering direct from them in the US. If you look hard enough you might find something local though but I don't know where. If you are not set on Magnacor you could try a very good locally made product, Aurora in Abbotsford
http://www.auroraignitionwires.com/
You should be able to find them at some of your local jobber outlets. THey might not have stock but ordering should not be a problem.
#3 Post by DaveB » Wed Feb 22, 2006 6:06 pm
I've generally built my own, using this tool:
http://www.rpmcat.com/images/T64-43390.jpg
a handful of these:
http://www.auroraignitionwires.com/22.5_dist_small.JPG
and these:
http://www.auroraignitionwires.com/str_dist_small.JPG
and these:
http://www.auroraignitionwires.com/str_term_small.jpg
and finally these:
http://www.auroraignitionwires.com/sm_b ... _small.jpg
all of which can be access from this main page: http://www.auroraignitionwires.com/components.htm
Pretty much any automotive store has all the stuff you need.
96whitedisco
Plug wires
#4 Post by 96whitedisco » Wed Feb 22, 2006 8:49 pm
Thanks for the input guys!
I went to Disco Tec the other day, as its just over the bridge and had a few questions and it was like i was speaking a differnt dilect of english.
Im finding that no one likes to fiddle with these engines witch is a shame as i used to work at a speed shop and the principles are the same.
The more air in and out the better the engine will run and ignition is another matter for improvement. There are cams available for these engines and some sweet head work can be done. I guess its what you are willing to put into the landy is what it boils down too!
Andrew
P.S i will start taking pics of the stuff im doing to my disco
nakedbarra
Mud Pit Boss
hmmmmm
#5 Post by nakedbarra » Wed Feb 22, 2006 10:36 pm
Hay there Andrew I am putting a 4.6 in my 93 rangie and through my research I have come to realise that the ECU in land rovers is very conservative and finiky about increased air flow and mixtures and stepping not to far from standard and the UCU cant keep up so here is a web site to do a little research on performancing your engine and you will find an ECU upgrade highly recomended if you port and air intake. www.rpiv8.com
96whitedisco
Hi Judge!
#6 Post by 96whitedisco » Wed Feb 22, 2006 11:08 pm
Well I think the 96 has coil banks and im running stock lucas wires and new bosch quad 4 and a K&N. i have taken the air box out and cut most of it away, Then i removed the resonator.The Disco runs alot stronger and im not stopping there i will tweak and tweak. dont fogret get more air in and out makes the old girl happy. computers can be manipulated. Ihave some friends in the software and hardware computer, i need to have a little chat
Andrew
nakedbarra
Mud Pit Boss
hmmmmm
#7 Post by nakedbarra » Thu Feb 23, 2006 7:29 am
I'm not running he banks and will be running the same set up as you have,Distributor setup.
