Hi All:
where is the flasher unit on a series 3 and how difficult is it to access. Thanks, Larry Emrick
flasher unit
larry emrick
Re: flasher unit
On my Series 2 it’s forward of the speedometer
larry emrick
Re: flasher unit
Thanks for that. It was the answer I was afraid of. The last time i delved behind the dash I burned up the wiring. won't do that again.
Larry
Larry
Re: flasher unit
If you disconnect the negative lead on the battery, you won’t start any fires.
