For sale. $199.00
Britpart Automatic Transmission Filter conversion kit.
Fits LR3, LR4, Range Rover Sport ‘05 - ‘13, Range Rover L322.
Description as written:
“This is an easy change filter conversion kit for all vehicles with either a 6HP26 or 6HP28 ZF 6-speed automatic gearbox - Discovery 3, Discovery 4, Range Rover Sport and Range Rover L322 models. From the factory a fluid and filter change on this transmission is a very lengthy process. The sump and filter are normally one piece and fitting involves jacking the engine up and unbolting the mounts, plus the removal of the exhaust. The fitting of this kit is far easier. Once the fluid has been drained from the transmission simply remove the bolts from the old unit. Cut the old plastic sumps filter tube with a hacksaw. Slide the old sump out and remove the other end of the sawn off filter tube. The new separate filter can then be fitted and the new sump pan slides into place and is bolted up with the new gasket supplied. Once secure the transmission can be filled as per manufacturer’s instructions. The new sump pan also has the added benefit that it is manufactured in durable steel rather than the plastic of the original item.”
Britpart Auto transmission filter conversion kit.LR3/4, RRS ‘05 - ‘13, RR L322
Amadreas
- Wet and Wild
- (169.01 KiB) Downloaded 57 times
