DIY Portal Axle???
DIY Portal Axle???
#1 Post by bsa_m21 » Sun Feb 14, 2021 6:04 pm
Came across this. Can't believe it would last very long. The torque on the bracket when off-roading would be ridiculous.
Kudos for inventiveness though... :1tonpull:
(256.13 KiB) Downloaded 121 times
Re: DIY Portal Axle???
#2 Post by red90 » Mon Feb 15, 2021 12:30 pm
A quad with no brakes which is good because if you used brakes the suspension would collapse.
If you want to see real home made portals look up Bill Larman.
