Engines from the UK
landcrabmechanic
Hot Manifold
Engines from the UK
#1 Post by landcrabmechanic » Thu Jan 07, 2021 8:29 am
Hello all.
My TD5 has finally arrived from the UK. Time to get it ready for install into my disco.
I have an engine supplier in the UK if anyone would like a TD5 for their trucks. You can deal directly with as I am not and will not be a middleman, which will also save you money.
Also have a great shipping agent and company to get the parts delivered to Vancouver.
PM me for details.
Scott
Tony4921
Re: Engines from the UK
#2 Post by Tony4921 » Sun Jan 17, 2021 7:04 pm
Hi. Did you get the TD5 with wiring harness and ECM complete?
landcrabmechanic
Hot Manifold
#3 Post by landcrabmechanic » Wed Jan 20, 2021 10:06 am
Hi Tony,
I got everything, minus AC compressor so I hope I can make my V8 one fit. Even got an extra core turbo and extra core alternator.
Full harness including fuse panels. Ecu I got separately as I needed one for an auto.
I am now going through the engine and will bench run it before installing.
Would you happen to have a nanocom I could use for disabling of the immobilizer?
If not I have found a way to do it, it is just more complicated than the nanocom way.
Scott
Tony4921
#4 Post by Tony4921 » Wed Jan 20, 2021 6:51 pm
My Nanocom only has TD5 engine on it, not Defender. I did not know you could disable the immobilizer. I will send a pm about your contact. I want to build a D2 TD5 also.
landcrabmechanic
Hot Manifold
#5 Post by landcrabmechanic » Wed Mar 03, 2021 9:45 pm
Hi Tony,
the nanocom td5 should disable the immobilizer.
Once I get thie engine prepped and ready to run, would I be able to borrow for a couple days?
I am also looking at buying a nanocom for myself. Is it worth the money?
Scott
acg
Cylinder bore
#6 Post by acg » Fri Mar 05, 2021 11:46 am
Scott,
I also have a Nanocom (D2 V8 Motronic) that you can borrow for a few days if you like. I live in Chilliwack.
#7 Post by bsa_m21 » Sat Mar 06, 2021 7:51 pm
Andrew,
Will your Nanocom also do D1’s.
acg
Cylinder bore
#8 Post by acg » Sun Mar 07, 2021 1:01 pm
Marty,
Unfortunately, my Nanocom only came with software for a Disco 2 - Motronic V8.
landcrabmechanic
Hot Manifold
#9 Post by landcrabmechanic » Sun Mar 21, 2021 8:20 pm
acg wrote: Fri Mar 05, 2021 11:46 am Scott,
Thanks for the offer, unfortunately, I would need the td5 nanocom.
I just ordered the Faultmate msv2, blackbox-solutions has said it will do everything the nanocom will do for td5 as well as the D1 stuff.
Will see if it actually works.
Scott
