The Twelve days of Rovalution Used Parts Sale - December 2020 - DAY SEVEN - 300Tdi LT94 4-speed
Check here to see items for sale, special offers and more from our vendors. Support your local Land Rover businesses!
bclandrover
#1 Post by bclandrover » Thu Dec 10, 2020 9:18 pm
Day Seven
I'm reluctant to let this one go, but happy if it goes to a good home for the right $$$$
Good Functional 4-Speed LT95 Transmission with 300Tdi to V8 Bellhousing adapter and spare LT95 parts...
https://drive.google.com/uc?id=1pqAVMcc ... XS0almbiYW
https://drive.google.com/uc?id=12y1VmJd ... KKFQZ1RkVO
https://drive.google.com/uc?id=1NtpO4TL ... i9tHT__BT0
https://drive.google.com/uc?id=1w3INZEz ... hcy7XrCCE1
ALL PARTS ARE AS IS WHERE IS - NO WARRANTY - NO RETURNS - NO EXCHANGES
rayhyland
Drip Dry
Re: The Twelve days of Rovalution Used Parts Sale - December 2020 - DAY SEVEN - 300Tdi LT94 4-speed
#2 Post by rayhyland » Thu Dec 10, 2020 9:41 pm
Does that mean with that adapter you could put it into a vehicle with a V8 rather than a TDI? Like if someone wanted to make their RRC a manual?
bclandrover
#3 Post by bclandrover » Thu Dec 10, 2020 9:49 pm
I should have mentioned this built-up LT95 is a SHORT V8 bellhousing and WILL bolt directly to a V8 engine but not exactly in any factory configuration without converting back to the standard long bellhousing. I have the all the parts and bucket loads of LT95 parts stashed around.
The adapter is from M&D engineering and allows a 300tdi or 2.8TGV diesel engine to bolt to this normally only V8 4-speed Transmission.
For the record there was over $5000 invested into this set-up "over the years" and i only did about 2000-3000miles before being swapped out for the 5-speed.
bclandrover
#4 Post by bclandrover » Sat Dec 19, 2020 1:32 pm
Hmm, maybe I'll just keep this and build a bush buggy... in another life time!
