Rear Crossmember
shuswapkid
- Rookie
Rear Crossmember
Re: Series 2 Rear Crossmember
Did you already try Jeremy at Rocky Mountain Parts, he normally has some?
mel rover
- Half Shaft
I will be bring in a pallet from the UK I could bring you one in would coast less then others
shuswapkid
- Rookie
Many thanks for that source ANDYD. Would you happen to have his contact info?
shuswapkid
- Rookie
ok
Hi, if you look for the top post in the "Parts wanted" section you will find all the contact numbers,
shuswapkid
- Rookie
Contact numbers noted. Thank you
