RRC / Disco 1 lift blocks
jeepingpw
- Worm Gear
Looking for a complete set (Front & Rear) 2" lift blocks to fit a RRC / Disco 1
DBrands
- Wing Nut
Re: RRC / Disco 1 lift blocks
The local metal supply should have some 4" round alu rod.
Years ago I had two 1" 'cookies' cut which I drilled mounting holes in myself to match the lower spring perches (used them as a template).
It worked great for many years, is very cheap, and just needs some longer fasteners.
David
David
