Series Rear Axle Case
oldgravy
Captain Crunch
#1 Post by oldgravy » Fri Apr 17, 2020 7:31 am
Hello, hope everyone is safe and healthy.
Looking for a series rear axle case / housing. I have diffs, axles, everything from two axles except that both housings I have are probably NFG without some work.
Unless someone has a cheap Salisbury? :wink:
Cylinder bore
Re: Series Rear Axle Case
#2 Post by John » Fri Apr 17, 2020 8:08 am
88" or 109"?
Bern B
Hot Manifold
#3 Post by Bern B » Fri Apr 17, 2020 8:14 am
I ve got some you can have a look at
(506.37 KiB) Downloaded 188 times
oldgravy
Captain Crunch
#4 Post by oldgravy » Sat Apr 18, 2020 8:55 am
109. Is there a difference?
Bernie is that one in the background? Where are you located?
Bern B
Hot Manifold
#5 Post by Bern B » Sat Apr 18, 2020 9:15 am
In in POCO
The one with the wheels is gone but I have some more on a pallet that I can have a look for.
Bern B
Hot Manifold
#6 Post by Bern B » Sat Apr 18, 2020 1:15 pm
Yes I have one if your interested
oldgravy
Captain Crunch
#7 Post by oldgravy » Mon Apr 20, 2020 8:48 am
Hi Bernie, emailed you through the site. Let me know how I can contact you?
