Hi All,
Hopefully someone has some experience with this set up
I purchased a Terrrafirma Swig out Spare Wheel carrier ... 2 basic parts, one bolts to the body, and on bolts to the door ... here is the question, Is the part that bolts to the back door suppose to have a piston that slides in/out to accommodate the movement difference between the door mounted hardware and the body mounted hardware when the door is opened / closed? My stuff doesn't seem to move ( and the vendor doesn't know how its suppose to work ) ... the install instructions are limited as best .
a video of yours working would be wonders for my frustration level
Terrafirma Swing out Wheel Carrier
Re: Terrafirma Swing out Wheel Carrier
It would be helpful to know what vehicle you are putting it on. :D
Navi
It was /is going on a D90
Not sure... even out of the box the "piston" didn't slide in the tube .... I originally thought there might be a spring inside ... but can't see ... I'm going to mess around with it later today... if i figure something out I will update ...
now that it appears it should move, i will work at getting it moving ... we shall see
Well if figured it out .... I had to use a press to get the "piston" out .... there was a seam in the tube that was sitting proud and had the nylon bushing jammed in place. some work with the rotary sander and its now working
All done now
All done now
