Lightweight build for Overlanding
Ryukyurvr
- Junior Craftsman
So, bought a 73 Lightweight and discovered upon receipt it came with front disk brakes! Only, I don’t know if it’s a custom conversion or a kit I cannot figure out who made and as the truck has gone through several owners since it’s importation to the US I’ve run out of people to call to figure it out. So I’m posting pictures and see if anyone else can tell me about it!
- (258.87 KiB) Downloaded 196 times
- (357.56 KiB) Downloaded 195 times
rgallant
Re: Lightweight build for Overlanding
I suspect you have found this web site, but just in case
Series Land Rover disk brake conversions
I think you might have this Pre-2010 disc brake conversion kits are based upon the disc brakes that come on the Spanish built Santana PS10 (Iveco Massif). There is link to the very basic PDF info below
Early Conversion
Hope this helps
Early Conversion
Hope this helps
I thought that they might be Girling 60 Calipers that were fitted to a variety of 90's VW and Audi's.
https://forums.vwvortex.com/showthread. ... -on-my-mk2
https://www.myturbodiesel.com/d2/1000q/ ... r-swap.htm
But it's a bit difficult to tell from your pics. Can you find any markings on them? Make and part no?
M.
M.
