1992 RRC
Transmission Cooler is leaking.
Any one replace theirs with an aftermarket one ?
Anyone know the steel line fitting size and if there is an adaptor to screw into the stock line that has a hose barb for rubber hose ?
RRC Trans Cooler
jeepingpw
- Worm Gear
Re: RRC Trans Cooler
I expect you have already found this RR forum? Lots of similar questions ....
https://www.rangerovers.net/threads/tra ... st-1670721
Good luck
Good luck
landcrabmechanic
The steel line is 1/2" and you can go no newline and get field servicable fittings and compression fittings. Where are you located? I can show you how I repaired mine. I am in east van.
Scott
Scott
