Does anyone have any information on this 1973 S3 88 (stripped) in Vancouver? Perhaps the owner is on this forum?!
https://vancouver.craigslist.org/van/ct ... 33267.html
I've requested pics.
Any info or advise is appreciated. Private message me if you prefer.
I'm looking for a project.
1973 Series 3 88 on Craigslist Vancouver
Danger Zone
- Junior Craftsman
Re: 1973 Series 3 88 on Craigslist Vancouver
Check the bulkhead for rot. Its all repairable and lots of parts are available.
Check the dash components very closely. It’s mostly thin sheet metal covered with a bit of foam and vinyl. The sheet metal rots out quite often and then it’s mostly the wrapper holding everything soft of together. Painful to repair and no one makes aftermarket bits for it.
Check all the aluminum for rot wherever it was touching steel.
Check the swivel balls for pitting and if apart, the diffs for wear on the ring gears.
The term “solid frame” could mean many things. Check the outriggers, rear x-member and undersides of the frame for bad rust.
Buying a vehicle in parts pretty much guarantees that some bits will be missing. the difficulty will be determining what.
Also check out: https://www.youtube.com/watch?v=30tKu9BRabI
Have fun!
Have fun!
Danger Zone
- Junior Craftsman
Thanks for the advice BSA, greatly appreciated.
