Sold Lucas starter motor, dated 09/50 (12 v) 2551 4D M418G
Rambler
Over Inflated
#1 Post by Rambler » Mon Nov 04, 2019 2:29 pm
SOLD
Having a sort out. Lucas starter motor for early series 1 Land Rover. The shaft moves smoothly, but would likely need stripping to clean up 50 years of grime, and to assess. Date stamped 09/50.
Other numbers are 2551 4D M418G and G76, 12V. Can be fitted to later series 2, 2A and 3 models, as the same bolt pattern.
$40 plus shipping, obo.
(123.32 KiB) Downloaded 204 times
(115.9 KiB) Downloaded 204 times
(129.53 KiB) Downloaded 204 times
leafsprung
Apprentice
Re: Lucas starter motor, dated 09/50 (12 v) 2551 4D M418G
#2 Post by leafsprung » Tue Nov 05, 2019 8:41 pm
Can’t be for 50, 80 inch uses a different starter.
#3 Post by bsa_m21 » Tue Nov 05, 2019 9:16 pm
I believe that none of the Series Ones used this starter, irrespective of its date of manufacture. Lucas made this model from 48-50 for a variety of makes and models. Most likely it came from a Rover 60 or 75 sedan.
