Alternator for V8
Roadqueen17
Worm Gear
Alternator for V8
#1 Post by Roadqueen17 » Wed Jul 17, 2019 6:16 pm
New alternator for a V8; came with my Defender but I have a 300 Tdi so can’t use. No brand marked only these numbers.
Located in Burnaby just off Hwy#1. Asking $200.
604-838-0528
(390.87 KiB) Downloaded 317 times
(559.96 KiB) Downloaded 317 times
(744.81 KiB) Downloaded 317 times
(756.26 KiB) Downloaded 317 times
(745.54 KiB) Downloaded 317 times
BlkP38
Bumper Sticker
Re: Alternator for V8
#2 Post by BlkP38 » Wed Jul 17, 2019 10:38 pm
Hi There,
That 100 amp alternator came from Red 90, so he might have some input. Sold suitable for a 300tdi.
Eric.
Roadqueen17
Worm Gear
#3 Post by Roadqueen17 » Thu Jul 18, 2019 7:20 pm
I needed an alternator just after the Rally in the Valley and Alistair at Hesp said he’d install for me then discovered that it’s for a V8. Not proper connections for tdi.
#4 Post by red90 » Thu Jul 18, 2019 8:11 pm
Roadqueen17 wrote: Thu Jul 18, 2019 7:20 pm Not proper connections for tdi.
Huh? I think someone is mixed up. As long as the mounts line up, it is the right one. Wiring is the same for all engines. If it one that I sold, I guarantee it is the correct OEM 100 Amp alternator for a 300TDI.
AMR5425
https://www.woodauto.com/product/ALT12025
#5 Post by red90 » Thu Jul 18, 2019 8:32 pm
This is the V8 version. The difference is the feet are closer together. The side view makes it clear this is the TDI one that you have.
Wiring is the same.
https://www.woodauto.com/product/ALT25002
#6 Post by red90 » Fri Jul 19, 2019 8:45 am
300TDI, 100 Amp altermator. If putting in a Defender, you should put in a larger gauge wire to the starter.
https://s3-eu-west-1.amazonaws.com/wood ... /1543l.jpg
V8 Alternator.
https://s3-eu-west-1.amazonaws.com/wood ... /2932l.jpg
