SOLD It time for me to make room for some other Land Rover projects, so I've decided to sell my 110.
Here are the details:
1987 Land Rover 110 Defender, exMod (ex military), 3 door, single cab hardtop but comes with hood set for convertible setup, 160,000 kms, full time 4wd with high/low range center differential lock, 2.5 liter NA diesel, 4 speed, rear mount fire extinguisher, pick and shovel mounts, all fluids recently changed, valve adjusted, new brake fluid, new master cylinder, new slave cylinder, new fuel filter, military convoy switch, custom dash panel with usb charger and voltmeter, new windshield, new vent rubber, soundproofing, new door panels, rear bed inward facing seats, hi-lift jack mount, new led front light bar, bush bar, new yokohama geolandar all terrains tires. Ex Military land rovers differ from civilian models by having these modifications from the factory: Front Bumper with towing pin and flag sockets, Nato rear hitch and 12 pin trailer socket, sidelights and indicators with glass lenses, Bonnet catches, Swivel Gaiters, Extended gearbox and axle breathers, Rear bumperettes, Headlight/blackout switch, Removable Cross Member, Fuel Filter extension for jerry can filling. This Land Rover is used as a daily driver, it has dents on the body but has no rust issues, gets almost 600 kms per tank and is very reliable and fun to drive.
Link to craigslist ad with photos. https://vancouver.craigslist.org/rds/ct ... 44493.html
SOLD 1987 Land Rover 110 Defender
ryancr500
- Tomb Raider
