Defender Coil Springs - SOLD
Posted: Wed Mar 27, 2019 7:12 pm
Good used Medium Duty Coil Springs that I took off my 110 when I upgraded to Old Man Emu Heavy Duty Springs :bounce:
$100 for the set of 4 - I can bring to Founders Day if needed.
-Andy
Re: Defender Coil Springs for sale
Posted: Wed Mar 27, 2019 8:39 pm
by landcrabmechanic
Hi Andy, I would like these. Do they fit on a disco 1?
I hope so.
Scott in Vancouver
604 763 2999
Posted: Wed Mar 27, 2019 8:41 pm
by ryancr500
Hey Andy I’ll take the springs
I an pick up at founders day
Ryan
Posted: Wed Mar 27, 2019 8:58 pm
Hi Scott,
I don't believe they will fit on a Disco 1. The Disco springs are smaller.
Hi Ryan,
As Scott posted first I will give him the first option to buy, if he doesn't want them then they are yours,
Posted: Wed Mar 27, 2019 8:59 pm
by ryancr500
No problem Andy
Ryan
Posted: Thu Mar 28, 2019 9:00 am
by bsa_m21
FYI - The Defender front springs in Andy's set are the same as stock Disco rear springs, and can be used on the front of a D1. The rear springs are about 2" longer then D1 rear springs and have a WAY heavier spring rate. You could use them on a Disco 1, if you have a roof rack and tent and other heavy stuff in the truck. Otherwise it would feel like a solid rear end and sit really high.
Martin.
Posted: Thu Mar 28, 2019 9:05 am
by landcrabmechanic
Thanks Martin.
Posted: Thu Mar 28, 2019 9:08 am
bsa_m21 wrote: Thu Mar 28, 2019 9:00 am FYI - The Defender front springs in Andy's set are the same as stock Disco rear springs, and can be used on the front of a D1. The rear springs are about 2" longer then D1 rear springs and have a WAY heavier spring rate. You could use them on a Disco 1, if you have a roof rack and tent and other heavy stuff in the truck. Otherwise it would feel like a solid rear end and sit really high.
Martin.
You can't use the rear springs in a Disco. They are different diameter (7" versus 6").
Posted: Thu Mar 28, 2019 12:18 pm
by bsa_m21
Oops. Forgot that.
All RR Classic, Disco1 and D90 coil springs are 6" OD.
110 and 130 Front springs are 6" OD. Rear springs are 7" OD.
These are Britpart springs.
(145.25 KiB) Downloaded 323 times
M.
Posted: Thu Mar 28, 2019 6:51 pm
by landcrabmechanic
Hi Andy, could you DM me your phone number? I can come to steveston tomorrow after some med appts. Thanks
Scott
Re: Defender Coil Springs for sale -SOLD
Posted: Sat Mar 30, 2019 7:03 am
Now SOLD ,,, thank you
