Defender Coil Springs - SOLD
Good used Medium Duty Coil Springs that I took off my 110 when I upgraded to Old Man Emu Heavy Duty Springs :bounce:
$100 for the set of 4 - I can bring to Founders Day if needed.
-Andy
-Andy
- (316.6 KiB) Downloaded 373 times
landcrabmechanic
Re: Defender Coil Springs for sale
Hi Andy, I would like these. Do they fit on a disco 1?
I hope so.
Scott in Vancouver
604 763 2999
I hope so.
Scott in Vancouver
604 763 2999
ryancr500
- Tomb Raider
Hey Andy I’ll take the springs
I an pick up at founders day
Ryan
Ryan
Hi Scott,
I don't believe they will fit on a Disco 1. The Disco springs are smaller.
Hi Ryan,
As Scott posted first I will give him the first option to buy, if he doesn't want them then they are yours,
Hi Ryan,
ryancr500
- Tomb Raider
No problem Andy
Ryan
Ryan
FYI - The Defender front springs in Andy's set are the same as stock Disco rear springs, and can be used on the front of a D1. The rear springs are about 2" longer then D1 rear springs and have a WAY heavier spring rate. You could use them on a Disco 1, if you have a roof rack and tent and other heavy stuff in the truck. Otherwise it would feel like a solid rear end and sit really high.
Martin.
Martin.
landcrabmechanic
Thanks Martin.
You can't use the rear springs in a Disco. They are different diameter (7" versus 6").bsa_m21 wrote: Thu Mar 28, 2019 9:00 am FYI - The Defender front springs in Andy's set are the same as stock Disco rear springs, and can be used on the front of a D1. The rear springs are about 2" longer then D1 rear springs and have a WAY heavier spring rate. You could use them on a Disco 1, if you have a roof rack and tent and other heavy stuff in the truck. Otherwise it would feel like a solid rear end and sit really high.
Martin.
Oops. Forgot that.
All RR Classic, Disco1 and D90 coil springs are 6" OD.
110 and 130 Front springs are 6" OD. Rear springs are 7" OD.
These are Britpart springs.
M.
M.
landcrabmechanic
Hi Andy, could you DM me your phone number? I can come to steveston tomorrow after some med appts. Thanks
Scott
Scott
Re: Defender Coil Springs for sale -SOLD
Now SOLD ,,, thank you
