Hello all,
Does anyone on here know what the red relay connector behind the right fascia kick panel is for on a 99 disco 1?
Also, on the 10AS module for the security system, is the red wire the sens wire for the fob when the button is pushed? If I make it longer will it make the remotes work better?
I also have an ABS 2-6 code ( brake light switch) . I have replaced the brake light switch and the abs code will not clear. any ideas?
Cheers and thanks
Scott
