Series 1 rear end, wheel , windscreen sold
Bern B
Offers
- (710.55 KiB) Downloaded 265 times
- (626.57 KiB) Downloaded 265 times
- (273.69 KiB) Downloaded 265 times
Re: Series 1 rear end, wheel , windscreen
I’m Interested in the rear axle Bernie. Does it have the fully floating or semi floating axles? Can’t tell from the pic
landcrabmechanic
It would be a full floater Matt. Semi float would have a removable differential cover.
I think your talking about the Salisbury rear end. This is a series one rear end so they didn’t have that option. I’m just wondering if it has the flat outer hubs that are integrated into the axel shaft as fitted to the 80”, 86” and 107” trucks also known as a semi floating axle.landcrabmechanic wrote: Sun Jan 27, 2019 12:13 pm It would be a full floater Matt. Semi float would have a removable differential cover.
