Where does this part go?
Posted: Thu Feb 11, 2021 3:05 pm
by Arcades
So this part fell off my truck yesterday... Can anyone tell me where it belongs?
Re: Where does this part go?
Posted: Thu Feb 11, 2021 5:15 pm
by bsa_m21
Why in my garage, of course! 🤗
Posted: Thu Feb 11, 2021 8:07 pm
by HeadDamage
You don't want that, it will not run worth a dam on diesel ;)
Posted: Thu Feb 11, 2021 9:57 pm
by Arcades
My thoughts exactly!
Posted: Thu Feb 11, 2021 10:03 pm
by Arcades
Well now I don't have to worry about fuel at all anymore
Posted: Thu Feb 11, 2021 10:05 pm
by Arcades
But look at my lift now... To think all I needed to do was take out the brick.
Posted: Tue Feb 16, 2021 1:19 pm
Hey Mark,
Finally time for that Electric Conversion? Where will you put the 18 batteries? :wink:
Posted: Fri Feb 19, 2021 10:56 pm
by Arcades
I just want to pay back everything that I got from you guys.... mainly the diesel exhaust fumes!
Posted: Sat Feb 20, 2021 1:09 pm
by acg
Mark,
Are you planning on replacing with V8 with something else? Or simply re-building the existing engine?
Either ways, good luck with the project. Looking forward to seeing you at one of our runs when the weather gets warmer.
Posted: Sat Feb 20, 2021 1:29 pm
by Arcades
This is going in....
It's a om606 turbo, a 6l90e transmission and a Ashcroft special transfercase
Posted: Sun Feb 21, 2021 7:45 am
by Tony4921
Nice mod. Where did you get the sump for the 606?
Posted: Sun Feb 21, 2021 3:26 pm
by Arcades
I met this super nice guy online that had done this conversion more than once (they are the goto non OEM swap in Europe). I ended up shipping all my parts to his place and then he boxed them up and sent them here in a single shipment. Saved a ton of shipping. Also he had great advice.
Posted: Sun Feb 21, 2021 3:27 pm
by Arcades
It's from an om648
Posted: Mon Feb 22, 2021 3:42 pm
by paulg_d130
keenly watching this so bring on the detail!
im toying with the idea of a om648 swap but still in the dreaming stage.
what did your get in your tcase? did you change the high range gears? add the ATB
Posted: Tue Feb 23, 2021 2:18 pm
by Arcades
It’s from Ashcroft. I HDed everything I could.. went to a higher gear set and the atb.
Posted: Tue Feb 23, 2021 2:26 pm
by Arcades
I figured that with all the torque from the new engine and the fact that I’m running 4.43 diffs I could use a higher gear.
Posted: Wed Feb 24, 2021 11:57 am
by Arcades
Posted: Wed Feb 24, 2021 6:55 pm
by bsa_m21
Mark - where are you doing, or getting the work done?
Posted: Thu Feb 25, 2021 11:11 am
by Arcades
It's being done at big country customs in Abbotsford. They also made my rear bumper for me amount many other things. They don't say no there.
Posted: Thu Mar 25, 2021 11:35 pm
by Arcades
Just a few shots of the progress... should be running in the next few days...
Posted: Thu Mar 25, 2021 11:45 pm
by Arcades
Intercooler pipes and exhaust
Posted: Fri Mar 26, 2021 10:09 am
by bsa_m21
Sweet! Looking forward to seeing and hearing it. 👍👍
Posted: Sat Mar 27, 2021 4:04 pm
by Arcades
Me too... me too
Posted: Sat Apr 24, 2021 11:46 am
by Arcades
The engine is now running... I would post a video but it's too large 😢
Posted: Sat Apr 24, 2021 11:53 am
by Arcades
Had an issue with the linkage for my transfercase. I had too move it back because of the longer transmission. I didn't want to cut more holes in the floor and cut up my automatic console. I found the solution by following what the English guys are doing when they swap Cummins in... Often they put in larger transmissions including alisons! They go with a pneumatic system.. maybe an alternative for the disco guys who want to put CDL in....
Posted: Sat Apr 24, 2021 11:54 am
by Arcades
Posted: Sat Apr 24, 2021 2:21 pm
by rgallant
Cool
Posted: Thu Apr 29, 2021 8:11 pm
by Arcades
So close now... Just setting up the transfercase then some linkages and she will be rolling along.
Posted: Thu Apr 29, 2021 8:14 pm
by Arcades
Engine bay cleaned up (almost) and pipes connected.
Posted: Thu Apr 29, 2021 10:53 pm
Looks great Mark, you will be ready for the long summer months of exciting mountain adventures and cozy camp outs 8)
I guess you will still need that extra fuel container though! :wink:
Posted: Thu Apr 29, 2021 11:25 pm
by Arcades
Should be able to get in the mid 20s unless I push the skinny pedal! Plus with the six speed transmission I have two overdrive gears...
Posted: Sun Jun 20, 2021 12:22 pm
by bsa_m21
Hey Mark,
How’s progress on the build? We going to see you on any trips this summer?
Posted: Thu Jun 24, 2021 10:39 am
by Arcades
Hi Martin... Thanks for checking in.
Posted: Thu Jun 24, 2021 10:43 am
by Arcades
So the engine is working like a top... having an issue with the transmission not shifting properly. I had the transmission rebuilt prior to installation. The truck was towed to the transmission shop yesterday. Sooo close. I will want to put miles on it before taking it into the bush. I know everyone that goes in comes out, but I don't want to have to rely on the club to deal with my mishugas.
Posted: Sat Sep 25, 2021 9:24 pm
by Arcades
Okay update... It was a setting on the controller... Shifting now... I've been driving it around for a couple of weeks... My new gauges are partially installed... The vnt mechanism for the turbo needs adjusting and after that the fuelling needs to be tweaked to the turbo.
Right now as long as I am slow and gentle on the throttle it behaves itself and a small puff of black smoke comes out the exhaust. If I really hit it then a massive black cloud comes pouring out. Very handy for tailgaters.
Posted: Fri Oct 01, 2021 12:39 am
by Arcades
Posted: Fri Oct 01, 2021 10:22 am
Getting close Mark, wont be long until you are playing in the mud again .... 8)
