2a Seat Ideas
gmorbey
- Grease Monkey
2a Seat Ideas
My 67' 2a 109 has brand new front seats (all three). I'd like to swap those out for 2 bucket seats and three point seat belts, possibly keeping the middle seat, or changing it to a console. Does anybody have some ideas on how this can be done a bit cheaper than Exmoor? Not that I don't like their stuff, quite the opposite I think, but it's a bit pricey.
Geoff.
Geoff.
Revor
- Muddy Tyres
Re: 2a Seat Ideas
Hi,
I have a couple of 110 front seats kicking around which would probably bolt in pretty simply, not sure if they would be bucket enough for what you are looking for. You can have them for free if you want. Good luck!
Ryan
Ryan
gmorbey
- Grease Monkey
Re: 2a Seat Ideas
Hi Ryan... Any chance I could see those seats? My schedule is pretty open.
My email is [email protected]
Geoff.
Geoff.
steveep
- Little Wheel
Re: 2a Seat Ideas
Hey Geoff, more controversial and you might have already come across my posts on the matter, but Smart Fortwo seats can work a treat. I did a lot of research into the same issue (being someone that can't afford to spend my way out of problems, but wanted to daily drive my truck) and they are what a lot of people in other car communities (old vans that have similar issues to us, and small race cars with other clearance issues) use, because they're comfortable, robust and have (to the best of my knowledge) the lowest seat profile of any modern production car.
You do need some simple risers to make them work (because the seat base extends below the mounting rails at a one point), but that is a popular mod for land rover seats anyways (to clear the lip behind the seat and get you more leg room)
Here's mine:
https://lh3.googleusercontent.com/pw/AP ... JyZc=w2400
I actually have another set, that I also used to solve my speaker problem (that pair has speakers in the head rest), for sale, but a pair shouldn't be too hard to track down regardless. Both of mine were custom reupholstered by their previous owners. The stock colors may be more to your taste.
This is the spare set I have:
https://lh3.googleusercontent.com/pw/AP ... Ko2g=w2400
Don't think it should be an issue leaving the middle seat in the middle, I'm pretty sure the difference in seat width is negligible.
Here's mine:
gmorbey
- Grease Monkey
Re: 2a Seat Ideas
Thanks for that... I did see posts on this. I did obtain some Defender seats from Ryan, so that is Plan A. They look like they'll work, but I'll get them in today to see how they work out.
Geoff.
Geoff.
InterMechanico
- Little Wheel
Re: 2a Seat Ideas
@gmorbey
Any thoughts to selling the front seats you’re removing? I could really use a new set to stop all the poking from my existing set lol
gmorbey
- Grease Monkey
Re: 2a Seat Ideas
Yes, they will need to go... However, it will just be the left and right cushion and frames. The new Defender seats worked out perfectly, but I'm keeping the center seat. The seats I have are refurbished left/right frames with brand new 3 Bros deluxe cushions. Send me an email at [email protected] if you are interested.
