Rebuilding Duffy
oldgravy
Captain Crunch
Re: Rebuilding Duffy
#76 Post by oldgravy » Thu Apr 24, 2025 1:43 pm
And for a small teaser at what I've been up to since then:
(26.24 KiB) Downloaded 62 times
#77 Post by ANDYD » Sun Apr 27, 2025 11:33 pm
Battery Connection ..... Start up?
cbalme
Slave Cylinder
#78 Post by cbalme » Mon Apr 28, 2025 9:05 am
Pinch clamp for a steering bar?
oldgravy
Captain Crunch
#79 Post by oldgravy » Mon Apr 28, 2025 10:53 am
*electroplating*.
And yes, it is a pinch clamp for the steering connections.
Seekerbeta
Beyond Recovery
#80 Post by Seekerbeta » Wed Jul 30, 2025 5:12 pm
with those ultrasonic cleaners, I found that evaporust pretty much restores the bolts in about an hour, my ultrasonic is both heated and vibratory, and I found keeping the evaporust Hot makes it work more effectively.
oldgravy
Captain Crunch
#81 Post by oldgravy » Fri Aug 15, 2025 10:00 am
Seekerbeta wrote: Wed Jul 30, 2025 5:12 pm with those ultrasonic cleaners, I found that evaporust pretty much restores the bolts in about an hour, my ultrasonic is both heated and vibratory, and I found keeping the evaporust Hot makes it work more effectively.
Thanks for the tip. I think in cases where you want the parts to be top coated i.e. with paint, that would be an excellent solution (pun intended.)
However I have found that the paints I have used just don't stand up, at all, on any kind of fastener. I painted my axle flange bolts and they stripped (the paint, not the thread) the second I torqued them.
Things like wheel nuts, or indeed any kind of bolt are usually visible and subject to damage from tools. If you're going to re-use an old bolt or nut, it makes sense to galvanize and then chromate it. Things like the pinch clamps could probably just be painted, I suppose, but it's not that much extra effort to wire wheel them, polish / clean them up with an abrasive brush wheel on a drill, and then run them through your next electroplating batch.
You don't have to use the blingy gold finish like cool 'n vintage do; I believe Dobbo just does a silver finish on his fasteners. But I do think they benefit from a sturdier coating than paint.
Seekerbeta
Beyond Recovery
#82 Post by Seekerbeta » Thu Oct 16, 2025 3:30 pm
oldgravy wrote: Fri Aug 15, 2025 10:00 am
i painted my lug nuts when i replaced my wheels, a soak in Evaporust, and a coat of Steel-it worked quite well, they have been on there since 2021 and multiple removals and torque sequences in all kinds of weather, they are just starting to look like they need a re-coat.
