Snapped half shaft semi floating series 1
NWOnt_1956
Learner Driver
#1 Post by NWOnt_1956 » Mon Nov 11, 2024 2:49 pm
Hi, I snapped a half shaft on my series 1 semi floating rear axle, or I’m pretty sure i did. I can spin the rear prop shaft by hand and no resistance in the rear diff. Any advice on replacing it? I have been looking at prices in the UK and seems real expensive. Thought or suggestions welcome. Thanks.
StuartC
Wing Nut
Re: Snapped half shaft semi floating series 1
#2 Post by StuartC » Tue Nov 12, 2024 7:47 am
Check out cumbrialrseriessolutions.weebly.com they may have a used one.
I don't think you have much choice....either you repair it or you don't.... :rolly:
bfein1075
Learner Driver
#3 Post by bfein1075 » Wed Nov 13, 2024 7:25 am
LRSOC has them and from what I recall the price isn’t that bad even if coming from the UK.
https://www.lrsoc.com/web/?s=Half+shaft ... les=0&fs=1
#4 Post by bsa_m21 » Wed Nov 13, 2024 11:01 am
The LRSOC 1/2 shafts are the full floating type. You can adapt these to your rear axle but would need a custom spacer and other fittings.
Here is an article on repairing the rear semi floating 1/2 shaft
https://www.landrovermonthly.co.uk/arti ... halfshaft/
I'd check with the lads at the Ottawa Valley Land Rovers (OVLR.CA). Quite a number have early S1's and might be able to help you, and they are closer than BC..... :bounce:
bfein1075
Learner Driver
#5 Post by bfein1075 » Wed Nov 13, 2024 11:09 am
My bad. Should have read that closer.
Thought they had both though.
tygre
Learner Driver
#6 Post by tygre » Thu Nov 14, 2024 8:17 am
Call Bill at Great Basin Rovers in Salt Lake City.
He has lots of used Series 1 parts.
#7 Post by ANDYD » Sun Nov 17, 2024 3:29 pm
Similar to what Martin mentioned above, if you can't find the S1's at a price that doesn't require a mortgage, its a good option if you adapt 2 old hub flanges into 1/2" spacers then you can use the much easy to obtain (and cheaper) series 2/2a half shafts.
The Series 2/2a half shafts are a little longer so the spacers allow them to work and its hardly noticable to the untrained eye!
I believe I showed some details on the spacers on my 1956 Series 1 restoration project (you can find on the project tab).
Tony8370
Newbie
#8 Post by Tony8370 » Mon Nov 18, 2024 5:43 pm
I have several S1 semi floating 1/2 shafts in Duncan.
