Disco 200TDI into 90
- Horn Blower
Ok,
Related to my other post about the 19J... Has anyone fitted a Disco 200TDI into a 90/110 without having to change the whole manifold/turbo set up to the Defender configeration?
- Horn Blower
How would that help? The 300TDI system is similar to the Disco 200TDI. You could use the 19J turbo, which is what a lot of people do to overcome the difficulties. http://forums.lr4x4.com/index.php?showtopic=15063
Note that if you change to the Defender manifolds, you need to change the timing cover as well as they interfere (as I understand it).
The exhaust is the big question. As I've read the conversions, it requires quite a complex downpipe. There is someone in the UK that makes them. The question is will it all clear the brake booster and the steering arm. http://steveparkers.co.uk/exhcon200tdi. ... 28507a1885
What are you going to put this in? Are not the engine mounts different as well?
When you do tackle it, let me know. I can come and lend a hand. It'll be interesting to see how it could fit.
Have a good look at this thread, http://forums.lr4x4.com/index.php?showtopic=2394 Lots of good pictures and you might be able to figure out if there will be interference problems.
- Horn Blower
I've just bought a disco 200tdi that was fitted in a LHD 110 using a 300tdi turbo. They had to jigger the exhuast down pipe a bit to get around the RH engine mount but it looks like alot better conversion than the steve parker down pipe with the disco 200tdi turbo. I haven't figured out what they did with the front end of the engine yet though I think that is stock disco 200tdi stuff. I'll likely be looking for a good electric fan because the water pump on this one looks a little low for the defender set up but the price was right and the engine was already in Calgary so I couldn't pass it up.
Glenn D.
- Cross Member
I'd like to see some pictures of this.
Is it easy to get 300tdi turbo manifolds? cause the 200 tdi defender ones are uncomon..
