1997 P38A 4.6HSE Kensington
Private Sales Only. Vendors/Dealers, pls use Vendors section. Sellers - Post must list the item(s) location. Pls mark post when items sold.
Forum rules
Tony4921
#1 Post by Tony4921 » Wed Apr 05, 2023 6:13 pm
Selling a true classic survivor, Its a rare Kensington Edition P38A. Everything works, no warning lights or symbols, still on fully functioning air suspension. The previous owner cut the floor under the rear seats to replace the bad fuel pump the lasy way. However gave up after he cut most of the hole. I have fitted a new fuel pump, and it runs like a dream. The roof lining is sagging quite bad in the rear, but I do not have the time to replace it. I do have a better roof lining to go with the car. The roof rail seals should also be replaced when the roof lining is out, as the look perished. No signs of water inside however. From my research, I have found very little info on these cars. Supposedly 650 were made in Black or British Racing Green, as this one is. They were taken off the production line and given higher level trim, top line stereo and the famous plate under the hood. It also has a weird 2 small, 1 large cup holder in the centre console. It was a US car so the odometer is in miles, and shows 134K miles. The paint is in very good condition, just needs a good polish, no rust. Offers.
(151.37 KiB) Downloaded 177 times
(83.6 KiB) Downloaded 177 times
(89.71 KiB) Downloaded 177 times
TylerN
Crank Case
Re: 1997 P38A 4.6HSE Kensington
#2 Post by TylerN » Thu Apr 13, 2023 1:16 pm
Do you happen to have pictures of the floor in the rear? Has it been repaired?
Tony4921
#3 Post by Tony4921 » Thu Apr 13, 2023 5:37 pm
No signs of repair anywhere
