Rebuilt in 2020 with new proper greaseable hardy spicer u-joints and a balancing @ Pat’s Driveline in Surrey. Has done maybe 5,000 miles since. Just greased it up and it’s ready to go. Should fit all 4-bolt diffs in any 300tdi or TD5 Defender. I swapped to a double cardan for more flex.
$100obo, pick up in Cloverdale
Defender 90/110/130 Front prop shaft 300/TD5
Forum rules
seatosky
- Half Shaft
- (892.92 KiB) Downloaded 91 times
Re: Defender 90/110/130 Front prop shaft
There are different length shafts as the transfer cases have different locations. You need to specify which arrangement this is meant to fit.
paulg_d130
- Little Wheel
Hey Spencer, did you swap in a double cardan from something else or have one made to fit?
seatosky
- Half Shaft
This fits 300tdi and TD5 from vin MA to 6A, equivalent part numbers are FRC8386 and TVB100610red90 wrote: Sun Oct 02, 2022 7:22 pm There are different length shafts as the transfer cases have different locations. You need to specify which arrangement this is meant to fit.
seatosky
- Half Shaft
I picked one up off a member who had it spare, it didn’t fix my vibration issues but I thought it was a good upgrade. Tom Woods will make you one for a relatively reasonable price.paulg_d130 wrote: Mon Oct 03, 2022 11:24 am Hey Spencer, did you swap in a double cardan from something else or have one made to fit?
