EV Electric Vehcile Builds
ryancr500
Tomb Raider
#1 Post by ryancr500 » Thu Sep 29, 2022 8:40 am
Thinking of doing a DIY EV conversion on a 1959 88". Hoping there are a few others doing conversions that can add some suggestions on best ways to proceed. My current thoughts are to purchase a damaged EV vehicle such as a Nissan Leaf or Chevy Volt.... but haven't committed to anything.
StuartC
Wing Nut
Re: EV Electric Vehcile Builds
#2 Post by StuartC » Thu Sep 29, 2022 8:53 am
You may want to check out pblarose's project in recent posts on the same subject......
ryancr500
Tomb Raider
#3 Post by ryancr500 » Thu Sep 29, 2022 9:12 am
I'll be following pblarose's build for sure.
#4 Post by red90 » Thu Sep 29, 2022 12:13 pm
Put aside $20k.
oldgravy
Captain Crunch
#5 Post by oldgravy » Fri Sep 30, 2022 9:35 am
More. There is substantial expertise required to adapt an existing EV to a non-native vehicle. Most people start with wrecked model 3's as they are more plentiful and there are more parts available.
If you want to get an idea of what's involved check out SuperFastMatt on YouTube, he did a model 3 swap into his classic Jag. The amount of work and engineering expertise is daunting... Which is one reason why the drop in kits are ~$100k.
I would love to see someone's completed setup as I think the idea is perfect for series land rovers!
#6 Post by red90 » Fri Sep 30, 2022 6:58 pm
You can do it for $20k. You just need to be able to design and understand the systems. It is not complicated but there are no cheap options unless you don’t want any range.
jacobko
Crank Case
#7 Post by jacobko » Mon Oct 03, 2022 4:21 pm
I got a quote for materials from a reputable EV supplier on Victoria island. Everything you need for the conversion including adaptor plate, motor, controller, charging system, cabling, and batteries for ~100km range was $27,000 after taxes. Buy everything in an engineered kit specifically for a series Land Rover and put it together yourself. At least that it what I would do.
Chris_W
Junior Craftsman
#8 Post by Chris_W » Tue Oct 04, 2022 11:24 am
I too am planning on electrifying my 62 station wagon. Frankly there are just so many options. From the basic Juant Motor (Netgain) option all the way to the Zero Labs skateboard chassis and everything in between. Currently I’m leaning in a Nissan Leaf/LT230 solution where I think you get the best bang for your buck. I think it would fantastic in this day and age if the Roverlander administrator would consider giving us likeminded users our own forum heading to promote Rover EV projects and builds
ryancr500
Tomb Raider
#9 Post by ryancr500 » Wed Oct 05, 2022 4:51 pm
I was thinking of the nissan leaf as well.... just need a decent wrecked donor vehicle.
Landydoni
Junior Craftsman
#10 Post by Landydoni » Fri Oct 07, 2022 9:38 am
jacobko wrote: Mon Oct 03, 2022 4:21 pm I got a quote for materials from a reputable EV supplier on Victoria island. Everything you need for the conversion including adaptor plate, motor, controller, charging system, cabling, and batteries for ~100km range was $27,000 after taxes. Buy everything in an engineered kit specifically for a series Land Rover and put it together yourself. At least that it what I would do.
This is the kit I ordered about a month ago for the conversion I'm doing. It was $32k after tax.
