Any recommended LR mechanics on the island?
A Forum for discussion between Rover enthusiasts on Vancouver Island
DuncanHague
Grease Monkey
#1 Post by DuncanHague » Sat May 08, 2021 7:39 am
As the title says, or indeed if there's anyone else who knows their way around discovery's like the back of their hands?
I just recently acquired a discovery 2 2004, I'd be interested to have someone who really knows these machines to give it a look over and probably point out a long list of things I could or should fix ha. Whilst I'm not too bad on the tools I'd happily pay a Land Rover Guru to check it over or some beers.
I'm based in Nanaimo. New to the forum so hi! Up for some steady adventuring in the local area too.
Thanks!
Duncan
Horn Blower
Re: Any recommended LR mechanics on the island?
#2 Post by HeadDamage » Sat May 08, 2021 11:28 am
Check with Rock Island Rovers.
rgallant
Cylinder bore
#3 Post by rgallant » Sat May 08, 2021 1:04 pm
You can start with this website as well https://landroverforums.com/forum/discovery-ii-18/ there is some solid information on there.
6 things to do right off
  • Have the front drive shaft checked for wear,any competent driveshaft shop can do that. If it lets go it can take out your transmission.
    Get a 327 ODB adaptor and Torque for your cell phone and monitor your actual running temps - the dash a gauge is functionally an idiot light
    Diffs, transfer case get a fluid change done, I run 75/140 Amsoil synthetic. But any good grade gear oil will work
    Exercise your Hi/Low CDL lever at least once every couple of months - it will get really sticky otherwise
    Check the oil weight and brand Rover V8's are not 5/anything engines. 10/40 is pretty solid year round choice here in BC. Ideally you want a good ZDDP level around 1200. Royal Purple HPS has it but there are other options. Most British guys use 20/50 synthetic.
    Full cooling system check. pressure test, and check the fan clutch and fan
The big worry on these is the engine, it is all aluminum with steel liners so any overheat is an issue. A a result of emissions controls they run hot so you have very little head room, ideally you want to run 188-194 highway and about 196-198 at idle before the fan kicks in. If you do not have a grey or black thermostat you want to get one and make sure it is marked 180F or do the inline thermostat change on the web site above. If you stay at 220 for an extended period you are fine, but you really want to cooler than that.
Finally these need regular maintenance nothing terrible, check your transfer case, coolant levels and regular oil changes about 4000 miles (6000Km).
They are pretty solid otherwise, just remember it is 18 years old stuff is going to break but I would say 85-90% of the work you can do yourself.
Here is mine this winter
https://i.imgur.com/kPHdufu.jpg
Greasy Fingers
#4 Post by Rob » Sun May 09, 2021 8:00 am
There are a couple of shops on the mid-island.
Mark's Import Auto in Nanaimo (I had good success with him and a D2 a few years back)
Sussex Auto in Coombs
And there is Tony (on the forum) who is very knowledgeable as well.
Regards, Rob
Tony4921
#5 Post by Tony4921 » Mon May 17, 2021 1:14 pm
Thanks Rob.
JoJo the Giraffe
Junior Craftsman
#6 Post by JoJo the Giraffe » Sun Apr 03, 2022 1:24 pm
I have ad good success with Frank Laird’s Auto in Ladysmith. Friendly and decent work
MakaluGreen
Rookie
#7 Post by MakaluGreen » Thu Jun 23, 2022 6:59 pm
Any recs closer to Victoria for LR mechanics?
Stu&Sly
Half Shaft
#8 Post by Stu&Sly » Tue Jun 28, 2022 8:15 am
Supposedly Marigold Auto Service on Burnside works on them. No experience with them so can’t say if they are tip top … or tip not.
