As per the rear, 609’s just about built… so, we have :
ARB locker
KAM 24 spline halfshafts & HD CV’s, these have the fusible link outer stubs and there is a spare.
Ashcroft HD drive flanges (thin type)
Again, is all built into a HD axle casing that’s double walled & fully armoured for an easy bolt in swap. Similar from Luck8 would be $3500+ on your doorstep…
$3000obo for a fully built 24 spline axle…. with very, very low miles… like in the hundreds…. :D
SOLD - D90 front HD axle set
Forum rules
LandyAndy
- Maxi Drive
paulg_d130
- Little Wheel
Re: D90 front HD axle set
are these setup for the early narrow bushing radius arms or the later wide bush style?
what ratio?
hubs\brakes included?
thanks!
Paul
what ratio?
thanks!
Paul
LandyAndy
- Maxi Drive
Radius arms are the 2” wide type, stock 3.54 ratio, is hub to hub & brakes included. Brakes are vented slotted & cross drilled rotors, hubs were fully rebuilt before we left the UK in ‘07 and it lived in the garage since we’ve been here not turning a wheel.
