Chev engine swap adapter
Private Sales Only. Vendors/Dealers, pls use Vendors section. Sellers - Post must list the item(s) location. Pls mark post when items sold.
Forum rules
Greg_M
Learner Driver
#1 Post by Greg_M » Sun Jan 16, 2022 10:16 am
It's starting to look like another Series LR is not going to be in my future. I used these parts to swap a 250 ci, inline 6 into a SWB IIA a lifetime ago. The best combination ever IMHO. The engine, which I lost track of after it went into a 67 C10, was rebuilt with an RV cam, aluminum intake, 390 cfm Holley 4BBL carb and it was a joy to drive. Endless torque, better mpg than the 2.25 l it replaced, and, with the Fairy OD, easily kept up with traffic on the 401 Hwy. Sorry for reminiscing but I miss that vehicle. Included are the bellhousing adapter, flywheel, pressure plate, starter (needs solenoid), and engine mounts. How does $750 sound? Open to trades as well. I've got a Disco1 so, yeah...
Located in Courtenay on Vancouver Island.
Cheers, Greg
(1.66 MiB) Downloaded 315 times
ryancr500
Tomb Raider
Re: Chev engine swap adapter
#2 Post by ryancr500 » Sun Feb 13, 2022 4:12 pm
I'm curious which model/years chevy motor would work with this?
Greg_M
Learner Driver
#3 Post by Greg_M » Mon Feb 14, 2022 7:57 am
Sorry, I really don't know the answer to that.
#4 Post by bsa_m21 » Mon Feb 14, 2022 9:46 am
Per the below, it is the same bolt pattern as a mid 90’s 4 bolt 350 SBC, which is the same as the LS1 pattern. Mind you, an LS1 will kill a Series tranny in no time at all. 🤔
http://67-72chevytrucks.com/vboard/show ... p?t=434639
#5 Post by swamijake » Mon Feb 14, 2022 12:18 pm
Also would work for a chev 4.3 V6 which might be a bit more a propos.
ryancr500
Tomb Raider
#6 Post by ryancr500 » Mon Feb 14, 2022 12:58 pm
I'll have to do a little more research!
TimberPig
Bumper Sticker
#7 Post by TimberPig » Mon Feb 14, 2022 11:16 pm
The Iron Duke 4 cylinders and the 230,250 and 292 inline six cylinders also use the same bolt pattern. The sixes generally need the six cylinder bulkhead to fit as the four cylinder won’t let them sit back as far in the chassis, at least without cutting. Depending upon which engine you try, the next piece to go is the gearbox as the Series gearbox won’t tolerate some of the more powerful options for long.
Greg_M
Learner Driver
#8 Post by Greg_M » Tue Feb 15, 2022 4:59 am
" The sixes generally need the six cylinder bulkhead"
In my case the 4 cyl bulkhead was unmodified with the 250 ci installed.
TimberPig
Bumper Sticker
#9 Post by TimberPig » Tue Feb 15, 2022 7:43 am
Greg_M wrote: Tue Feb 15, 2022 4:59 am " The sixes generally need the six cylinder bulkhead"
That must have been wedged in there as the 250 in my NADA 109 project I have here is not overly generous for room and it sits further back than a 2.25 does. Or you push the rad forward to gain clearance.
Greg_M
Learner Driver
#10 Post by Greg_M » Tue Feb 15, 2022 8:05 am
Yes the rad (not the stock rad either) was moved forward a bit and electric fans installed.
