SOLD - Thank you!
Hello All,
Finally listing our LR3 for sale, moving to Australia in mid-October so unfortunately it has to go.
Truck available first week of October, still using it to get around.
TRUCK IS LOCATED IN PEMBERTON
$7,000 OBO (happy to negotiate on price)
2007 LR3 HSE
Silver exterior, black leather interior
179,XXX Miles (288,XXXkm) - US import
Great truck, really sorry to see it go.
It's definitely not perfect, we used it off road during our ownership and we lived out of it for almost 6 months while on the road touring North America.
The GOOD
- Oil changed every 8,000km with Castrol Edge - 5W-30 and Genuine (or better) filter
- Front lower suspension bushes changed to polyurethane last summer
- Front drivers wheel bearing replaced last summer (Timken)
- Rear drivers wheel bearing replaced summer 2019 (Timken)
- All rear control arms changed summer 2019 with OEM parts (all parts say Land Rover on them but came in OEM box)
- Air conditioning compressor installed by Rovalution - August 2021 (Genuine used part)
- Full size spare tire
- All brake pads and discs replaced within last two years
- All brake caliper slides rebuilt within last two years
- Genuine rear prop shaft installed summer 2020
- Curt Manufacturing tow hitch installed
- Tekonsha brake controller installed
- Tactical Rovers bull bar installed
- Air suspension fully operational - does throw up the occasional code which is easily cleared with GAP Tool (Tool not included in sale) or re-starting the truck. It's related to one of the height sensors but happens so rarely I have never bothered to investigate.
- Transmission fluid and filter changed 2018. Used genuine ZF fluid.
- All differential fluids and transfer box fluid changed in 2018 and then 2020. Used Genuine fluids.
- BFG KO2 tires currently on the vehicle - passenger rear worn unevenly, issue with alignment last summer, fixed and drives perfectly straight. Rest of tires in great shape
- Goodyear winter tires to be sold with truck, lots of tread left
- Goodyear Wrangler MT's with at least 40% tread life left can also be taken
- Many spare parts (upper control arms and all bolts, passenger side front wheel bearing assembly, etc.) and specific fluids (ZF ATF fluid, Power Steering fluid, Beck Arnley coolant) to go with sale. I also have the original bumper which can go with the sale
- G4 challenge roof rack - I've altered it to sit lower on the truck but have all the aluminum parts to make it whole again
- 3rd row seats were removed for our trip but I still have them and all fixings and they're in good condition
The 'Wish it was better'
- Sunroof motor no longer works, stuck in closed position
- Drivers seat heat no longer works, passenger and rear seats still work
- A/C no longer works, compressor replaced but there is a leak somewhere in the system, most likely the condensor. Climate control system works fine otherwise.
- No parking brake installed - unit failed and was removed
- Front differential has a very minor leak, I check it regularly and I've only had to top it up once
- Steering rack has a slight leak and isn't as tight as it was originally. I've only had to top up the fluid once
- During recent work at Rovalution tech's noticed one of the wheel bearings will need replacement soon, they didn't note which one though.
- Some paint missing from driver's door
- Ghosting on some body panels from decals which were previously installed
I think I've covered most things, please feel free to reach out if you would like more information or would like to see the truck.
Thank you!
Jayson
(604) 203-1746
**Accessories in photos are not included in sale (awnings, maxtraxs, etc.)
SOLD - 2007 LR3 HSE For Sale
Forum rules
Overland Bunch
- Grease Monkey
