Koenig Pto Winch Removal questions
deanc5
Wing Nut
#1 Post by deanc5 » Thu Jul 15, 2021 4:42 pm
Hi guys, I will be back in Sicamous on August 1st to do some more work on my 1970 Series 2a project. I will be removing the complete Koenig winch, PTO, selector assembly, and driveshaft. Everything in the picture below (not my pic). I don't really know what is involved and what parts I will need. I know I will need a rear PTO cover plate and selector cover plate but is there anything else I should know? Does anything have to be done in regards to the main shaft?
Ps if anyone has the cover plates I need, I could be interested in purchasing them.
(11.6 KiB) Downloaded 95 times
Colin
Mud Pit Boss
Re: Koenig Pto Winch Removal questions
#2 Post by Colin » Fri Jul 16, 2021 11:59 am
Not as I recall, it should sell for a good price, they are excellent winches. Other than the transfer box cover plate, I think is it, as I recall the cover plated has needle bearings to support the output shaft from the Tranny?
deanc5
Wing Nut
#3 Post by deanc5 » Fri Jul 16, 2021 12:48 pm
Thanks Colin, yes that is exactly what I suspected. I'm wondering if there is a bearing needed in the PTO cover plate, or any other little details like that.
Colin
Mud Pit Boss
#4 Post by Colin » Sat Jul 17, 2021 1:05 pm
Not a great picture but the needle bearing is in the cone and generally comes with it
http://www.allfourx4.com.au/WebRoot/Sto ... 731__1.jpg
Slightly better picture
https://www.picclickimg.com/d/l400/pict ... 533731.jpg
Colin
Mud Pit Boss
#5 Post by Colin » Sat Jul 17, 2021 1:08 pm
Also Ray Wood might have an overdrive that would fit in the opening as an option?
deanc5
Wing Nut
#6 Post by deanc5 » Sun Jul 18, 2021 8:20 am
Ha, thanks for the bearing image. That helps a lot. No overdrive is needed. I'm using disco 1 axles and 32-inch tires. My final drive is already 1.56 times stock Series. I need to get some 4.37 or 4.76 gears.
