1965 Series 2A 109" SOLD
Private Sales Only. Vendors/Dealers, pls use Vendors section. Sellers - Post must list the item(s) location. Pls mark post when items sold.
Forum rules
DrRangelove
Hot Manifold
#1 Post by DrRangelove » Mon Jan 11, 2021 11:54 am
Hi Everyone,
I'm relocating to Ontario and my 1965 S2A 109" Land Rover is up for sale. You can see the build thread here for photos:
viewtopic.php?f=15&t=6548
29,000 original mils on the body/frame.
Complete body off frame rebuild - frame is solid and has zero rust/rot. It was primed, painted (2 coats) and waxoiled when during the rebuild (2016). The following components were replaced in 2015/2016 and have less than 1,000 miles on them:
- shocks
- bushings
- Wiring harness
- brakes including brake lines
- clutch including clutch lines
- converted to -ve earth with a new AC Delco alternator
- Fuel tank and fuel lines
- Axle seals and swivel gaskets. Swivel balls are immaculate with zero pitting
- Rebuilt hand brake drum with new components
- Head gaskets, spark plugs, belts all new
- Exhaust pipe and muffler
- Carb (I think I have a zenith on there)
- battery
- Gearbox and transfer case were gone through and rebuilt/resealed
In addition, the bulkhead was stripped, painted and is also rust/rot free. Bodywork was given a farmer's paint job which looks "Goodish" from 15 feet away. She's showing some battle scars on the bodywork, some guys call it patina.
She runs, drives and stops. I had her registered and insured on the road in 2017/2018 and was driving from Horne Lake to Parksville regularly until I parked it up in 2019. Since 2019 she's been used as a run around vehicle at the lake and is currently dry stored. Vehicle last ran in November 2020 and fires up every time.
I put a lot of time and love into the old girl since I owned her (you can see on the rebuild thread above) and she needs some minor things to be a reliable daily driver/runabout:
- New tires
- rear glass (safari door)
- stock throttle linkage needs installing (I have it and have just got a temporary linkage set up on there for now)
- windscreen wiper motors need going over
- No heater, but has the holes cut into the passenger footwell for one
Comes with a few spares (glass, floor pans, half shafts, hubs, head, fuel pump etc...) and a newer winch if you want it thrown in.
Asking $12,000
Located on Vancouver Island
Call 250 7390164 for more info
email: [email protected] for more photos
Note, I am currently in Ontario but can arrange for the vehicle to be viewed. I plan on making a trip back in February - I was a club member until recently and plenty on here can vouch that I'm a real person and not an internet scammer LOL.
DrRangelove
Hot Manifold
Re: 1965 Series 2A 109" SOLD
#2 Post by DrRangelove » Fri Jan 29, 2021 6:42 pm
The Landy is sold.
