Add some lights to my Disco
rgallant
While doing some routine maintenance I found some connectors behind the grill of my Disco and a pair of relays hidden at the end of the under hood fuse box.
I set up a quick test to confirm my suspicion it was left over driving light wiring
An old driving light used to test the circuit - note the very secure connection
https://i.imgur.com/XtNzBUA.jpg
And the test result
https://i.imgur.com/YRpCYjw.jpg
Now as it happens these are wired up as aux driving lights which means they only work with the hi-beams on, which means I can leave them uncovered in theory. I did order covers for rock protection. Additionally they use a stock Discovery 2 Switch so big win there.
https://i.imgur.com/3jjSgtj.jpg
My biggest challenge was how to mount the lights, I decided to give one of those aluminum license plate mounts for LED lights a try. As it turns out by adding two supports it should work brilliantly as the supports I added are going to carry most of the weight.
2 x 3 watt LED floods mounted, you can see the test support between the lights. I had to buy new female connectors but they turned out to be a stock connector from CDN tire.
https://i.imgur.com/FECkHRT.jpg
Once that was done I needed spotlight, I really liked the ones on @cmcgowan LR4 (my apologies for not remembering your 1st name) and the price for one was decent so that was ordered and installed. Currently I am only mounting one if it turns out I need more I can order an 2nd one and mount the pods elsewhere.
The pod lights are intentionally aimed slightly to the side for better lighting of the road edges.
https://i.imgur.com/6gucK7U.jpg
And few images of everything working - note no daytime running lights yet on the big light
Headlights only
https://i.imgur.com/NOuizoP.jpg
Everything, notice the reflection on the windshield cast back
https://i.imgur.com/MZUqSIO.jpg
Lighting up the neighbours house :)
https://i.imgur.com/l5sN459.jpg
And the test result
Headlights only
cmcgowan
- Beyond Recovery
Re: Add some lights to my Disco
Looks great! Now we can both light up the road for Andy
Ps- its Cody & Tanner
rgallant
@cmcgowan Ah thanks I had the Cody but was not sure, it takes me a time or 2 of meeting people for the names to stick.
cmcgowan
- Beyond Recovery
Haha no problem at all!
Did you connect the orange halo? I dont see it on in the photo?
rgallant
No orange halo yet, I need to tap the Day the Running lights. I figure I would wait until I decided if I need a second light.
cmcgowan
- Beyond Recovery
Cool looking forward to seeing it in person next weekend!
Sent from my iPad using Tapatalk
Nice, very enlightening :roll:
Make sure your not breaking any laws, you don't want a ticket like me & Martin were both slapped with!
I'm wondering if with all these lighting improvements that you're trying to send me a message that we've been getting into camp a bit late :lol:
rgallant
Funny enough that last trip was the push to get the pods mounted they have been sitting in the garage for 8 months :)
StuartL
- Horn Blower
And now you shall be known as "Cyclops" until someone backs into you or you hit something! :shock:
rgallant
@StuartL I had not thought about the Cyclops thing very good. :)
Amadreas
- Wet and Wild
Or the “Rhino”
Big thumbs, small keyboard.
Roadqueen17
- Worm Gear
Yes maybe that is the vibes being sent out to you Andy! Even Chris installed new LED heated headlights!ANDYD wrote: Sat Oct 17, 2020 8:01 pm Nice, very enlightening :roll:
