Is anyone running these tires on their Series I Disco?
235/85R16
255/85R16
265/75R16
If you are could you please describe your corresponding suspension set-up?
Disco I Tire Survey
96whitedisco
Just went throught this nightmare for tires depending on how many kms youre disco has, makes a big deal with tire size, the springs on my Disco are tired. i have a 96 and the largest size i could fit on was a 255 70 16, i had stock 235 70 16. i went with this tire as it is a little under a 31 inch tire yet is wider than the 245.
You can fit a 245 75 16 that have a hight of 31 inches, so depending on what you have done to the suspension means alot. Im talking in stock suspensions no lifts. When i put the 255 on there are only a few tire companys that make the size, one being bf and dunlop. I think the 235 85 16 is close to a 32 which i think you may need a lift and depending on what load rating could be a little tall and skiny for the landy, just my opion.
As i said im running stock suspension with pro comp shocks and im running 255/70/16. I just look and they are 10.4 inches wide and 30.4 inches tall.
Hope this helps
Hope this helps
jasonkennett
