Reluctantly toying with the idea of selling my Range Rover classic as I never drive it anymore and life has sort of gone in a different direction! Just rebuilt the LT230 transfer case and converted to a 1.4 ratio with a heavy cross pin center diff, and fitted a Global Roamer Overdrive. Ran great but, started making a spun bearing noise in that area while towing on the highway last year, and just parked it! Think I may have overheated the Overdrive! Only makes the noise under hard throttle now, but it should be investigated and I don't have the time!
Specs are:
1993 Range Rover Classic LWB, Roman Bronze
No Rust! Really! Replaced floor pans front and rear, foot wells, rocker panels , tailgate and hatch, and swapped in an early aluminum rear floor. Frame off job! All undercoated and resealed. Custom unfinished winch bumper not fitted but will through in at the right price!
35" Tires on 16" MRW Wheels
Fender flares
Converted to 24 spine axles, all new axles and CV's
ARB lockers front and rear - no air source to active so never used
4.43 Great Basin Gears
Custom Radius and trailing arms
Poly bushes everywhere
+4 RTE Springs with a small body lift
+2 OME shocks with drop mounts
Custom Snorkel
Disco 300tdi with fuel mods
New Cylinder head only 2K old
Allisport full width intercooler
R380 5 speed transmission
EGT and Boost Gauges
Rebuilt 1.4 LT230 transfercase
Global Roamer Overdrive - see above notes!
New lift pump
New clutch
Plus lots more I can't recall at the moment!
Located in Ladysmith, No trades! Offers on $12,000. PM is best as I don't get on here as much anymore!
93 RRC LWB 300tdi and lots of mods for sale
Forum rules
