Sounds like bad u-joints. There are only those two sizes. The smaller ones are not used on anything but Land Rovers so your dad won’t have any luck locally. The larger ones are 1310s and commoner than dirt.
I always use Hardy Spicer joints from the UK and they always fit.
I agree with Red90, except the smaller ones (Precision 344, Spicer/Dana 1300 series #5-3214x) are also used on Triumph TR2/3/5/6, Volvo 140/240/740, some Maserati models and more. :twisted:
You can buy the #5-3214x from most parts stores locally.
Here is a zip with a pdf of the hardy-spicer 1300 spec's. You can measure up what you have to see what's wrong. (Yours were probably made in China..... :oops: )
- Hardy Spicer 1300.zip
- (462.77 KiB) Downloaded 33 times
cbalme
- Slave Cylinder
Hi there, before I go out and buy new U joints I think it'll be worth taking this one apart and seeing if any pins have fallen over. I will find out either Thursday or Friday if that is my problem.
In the future I'll probably end up getting joints from the UK as the Hardy Spicer and GKN are surprisingly cheap compared to the MOOGs from the local shop.
cbalme
- Slave Cylinder
Haven't got a chance to take a look at those U-joints yet. But I have got quite a few other jobs done.
The clutch master cylinder has been replaced and as far as I can tell it works. It may need bled a bit more and the pedal height needs properly adjusted too.
I cleaned up the wiring from the Kodiak MK2 and found out that it's a two-speed motor which is nice because I don't need the resistor inside. They're now slightly wrapped in hockey tape which makes for a good disguise to match the rest of the loom compared to electrical tape.
https://i.imgur.com/ztsxb8Il.jpg
The Spade style dipswitch has been screwed into the footwell. I still need to drill a hole for the wires but that will come later.
https://i.imgur.com/xhCQi1xl.jpg
Since I wasn't able to find a Kodiak Mk 2 heater cowl, I had to find a solution so I wouldn't be sucking in engine bay fumes into the core. I got a Kodiak Mk3 heater and pulled the cowl off of it and screwed it onto the Mk 2 Heater. Here is what needs to be mashed together. A bit of a shame but this is much quicker than making the proper cowl for a Mk 2.
https://i.imgur.com/K3G28Evl.jpg
Cut it out, then screwed it to the Mk 2 heater thing. Where it is screwed may interfere with the matrix so it may have to be tack welded in place I will see tomorrow.
https://i.imgur.com/HyLt0lml.jpg
Also tried to make a Lucas Windtone horn work. I have stripped it and cleaned all the contacts I just think the points need properly adjusted. It does honk but only when you press the points together manually.
https://i.imgur.com/a6cMrIgl.jpg
cbalme
- Slave Cylinder
Still no luck getting those wind tone horns to work. I think I will just buy a Series 3 horn without points as much as I'd like to use a windtone.
My Kodiak MK 21/2 looks like it'll work perfectly. I bought some weatherstrip tape for the foam insert. It worked perfectly and is stuck in there good.
https://i.imgur.com/74BNztGl.jpg?1
Polished a few things like the wiper arms and warning lights. I will have to replace the lens on the red one but the orange one turned out good. I will have to buy a new oil warning light the one I got has faded from the sun or been painted over.
https://i.imgur.com/dHFjJygl.jpg https://i.imgur.com/c2smilMl.jpg
Took apart the wiper motors today for paint. The grease looks like Kreosote and is pretty gross
https://i.imgur.com/xVxWou7l.jpg
My other motor had already been taken apart and was gummed up with some gross white lithium grease.
Had to go all out and make the motors look fancy. Painted them gold which will look really nice inside the green interior.
https://i.imgur.com/UivMVesl.jpg
Hopefully I'll get the wiper motors back together tomorrow they just need some soldering and to regrease all the drive gear.
cbalme
- Slave Cylinder
Progress really slowed down this weekend, I did not get many 109 related tasks completed. Thankfully it is warm enough to paint and our compressor works, but I am just painting things the wrong colour it seems. These wheels and a set of hinges will go onto the 110 next weekend, then the booth should be green again!
https://i.imgur.com/GwTX3H0l.jpg
The wiper motors are back together and look really nice I'm very pleased with how they turned out. They've been regreased and just need testing but I have no doubts that they'll work. All the hardware for the wipers has been rounded up I just need to make new gaskets since I don't want to pay $20 or something like that for two.
https://i.imgur.com/iv8LN02l.jpg
Also got half the u-joints back together, still pretty stiff but should bed in overtime. When they wear out again I'll be ordering a set from the UK since they're significantly cheaper than buying MOOGs locally.
https://i.imgur.com/YJqMmkrl.jpg
Next weekend I hope to get a lot of painting done.
cbalme
- Slave Cylinder
Pleased to report that both wiper motors work. One just needed the swtich rivet peened over to tighten it further because it wouldn't turn the motor on.
While trying to save a bit of money I opted to buy just the lenses for the warning lights on the dash. The lenses were $15 or you could buy three brand new warning lights for $60 which is very expensive for a little piece of plastic. They are not too bad to take out, there are a couple methods mine was very crude but did the job. You can boil them in some water which is what I should've done but I was too lazy to walk up to the house. I found that if you punch a hole through them either by accident or on purpose, then bend the tabs and pry the lens out with the conviently placed hole. The housing doesn't get hurt at all in the process.
https://i.imgur.com/8O10mR1l.jpg
cbalme
- Slave Cylinder
Wasted a lot of time this weekend at Canadian Tire instead of restoring the Green Machine. I was told my tires would be ready at 2:30 only to be told that I was wrong and that they were booked in for 4:30. I assume they realized their mistake because I was out of there at 3:30 and had some new tires mounted for the 110.
I was able to sort out a couple of little tasks for the 109 like this brake light switch which is now hooked up and adjusted. I had to run a set of wires across the firewall which wasn't a big deal and they look as though they kind of belong so overall I am pleased.
https://i.imgur.com/1wKDOQzl.jpg
I also fixed the brake line rubbing issues on the truck. One line was up against the radiator so with assistance from my Dad we got it sorted. You may be able to see a brake line in this photo I am not sure.
https://i.imgur.com/ywanF1Il.jpg
cbalme
- Slave Cylinder
I have been very busy over the past month and haven't had much time to work on this project, but I have been slowly getting little tasks completed. The New Lenses arrived from the UK so those went into the warning light bezels.
https://i.imgur.com/1wH6RMUl.jpg
Wired in the Fusebox, the whole truck is run off of one fuse as far as I can tell. I will be fusing any extra modifications I make that is for sure but at the moment the system will stay stock except for the addition of a reverse light and alternator. I had to crimp on connectors and heatshrink them but that is all part of the job.
https://i.imgur.com/ATRAVvxl.jpg
Also picked up some Yokohoma 742s 7.50x16 tires at Founder's Day for the project and they look perfect! They are taller and Skinnier than the other tires I was looking at. The 235/85/R16 Toyo M55. Overall I am very pleased with them considering they came on defender rims. One day I will get around to painting the rims but that can wait until the truck is on the road. Also adjusted the toe in, before it was set very far in.
https://i.imgur.com/YZ3pzpel.jpg
They're much better suited than the old 6.50x16s on their previously
https://i.imgur.com/JA0GVyTl.jpg
I also waxed the inside of the bulkhead with the same products I used inside the frame.
Now that school is done for this year I can kick this project into overdrive and get it out of the barn and roadworthy for this year's rally! It may not have a roof by then and it may not come on the drive but it will be there that's for sure.
cbalme
- Slave Cylinder
Last week was quite busy but I was able to get a bit of work done before it. I was able to get a fair bit of painting done and left it to dry while I was at work. Last night I began reassembling everything to save time when putting the whole thing back together. I got the seat box back together except for the seat frames, which will get painted and installed in the next few days. I pushed all the captive nuts into place which was a real pain in the butt. They are very difficult to install.
https://i.imgur.com/9MyfoHKl.jpg
Then I put the Gearbox tunnel back together, which went well until I found out the stud was too bent to be used. I had to steal another stud off of a different tunnel to make mine work. I just drilled out the hammer rivets and installed new pop rivets in.
https://i.imgur.com/2ckSTL6l.jpg
Here it is completed. I still have to add some sound deadening to it but that can be done anytime. I also added a grommet to the 4wd plunger which should make the engagement nice and quiet with no metal on metal contact.
https://i.imgur.com/jsYsWL3l.jpg
Looks good with the floors installed, I may be getting ahead of myself
https://i.imgur.com/WmG6cFel.jpg
Added the doorstops with bolts that are far too long
https://i.imgur.com/LgpLEXql.jpg
Also painted all the hinges and installed a Horn. Due to not being able to find a working Windtone or Clear Hooter, I had to breakdown and buy a generic horn. Which turned out much better than expected! To my untrained ear it sounds sort of like what a windtone should sound like. One day I may upgrade to a proper English Horn, but at the moment it is installed and works. Best of all there are no points to mess around with.
https://i.imgur.com/ZQBAVM5l.jpg
This weekend I will be repainting my doors and doortops because they turned out very bad and then it's onto prepping the box. I am still on the fence whether it is worth bedlining or just spraying with endura but I have to make my decision soon.
cbalme
- Slave Cylinder
Haven't really got much done over the past few weeks, The farm is busiest during May so it's unlikely the truck will be driving at the rally. The biggest job is still the galvanizing and I'm not sure if I will as I have a good set of cappings in the barn.
I have got a few little jobs done but they all add up. Like the vent seals. I installed new style vent seals from '92 trucks but they work for series. I was hoping that they'd glue to the bulkhead but they seal nice and tight now with vent controls I cleaned up for the meantime until I can get a set replated.
https://i.imgur.com/ujGRCtQl.jpg https://i.imgur.com/0nAkYeTl.jpg
The seat box is ready for installation and is now in storage, it needs a few more things added like turnbuckles and seat holders once the hardura is added.
https://i.imgur.com/nbvVMkil.jpg
The doors and doortops have been repainted after I messed the first paintjob up.
A local dormobile owner told me that the handbrake could be taken apart so I could paint it. I should've ignored him but I gave it a shot, and this happened.
https://i.imgur.com/wMwwjnNl.jpg
So I decided that since I have two others, why not try them? Now I have one handbrake, but turns out it is from a Series 1....
Here's my solution. I was able to save one button so one handbrake could be made, I just had to find something to replace the rod. I was looking all over the shop and moved this bucket to look behind a shelf. It was almost perfect, although 0.5mm shy of the original thickness it would do the job since the threaded section was thinner.
https://i.imgur.com/8UBHraEl.jpg
I bent it straight, put the 90 degree bend in the end and then tapped the other end and screwed the knob on. Here it is in its glory. I also drilled the small hole on the bent end for the split pin.
https://i.imgur.com/aNm610Ml.jpg https://i.imgur.com/jgLKRWcl.jpg
All that is left to do is test it! That'll get done tonight once the handbrake is dry.
May is coming to an end so once all our crops are dealt with I will be able to put quite a bit more time into this.
cbalme
- Slave Cylinder
This evening I was able to reinstall the handbrake. It took a bit of fiddling to make my new piece work but now it is as good as new.
https://i.imgur.com/YbJdlCgl.jpg
Also did a bit of work on the electrical. I checked the mixture warning light for continuity and there was none so I took the switch apart and adjusted the rod until contact was made when the choke was pulled out.
https://i.imgur.com/NCc8VEBl.jpg
After that I cleaned up the headlight wiring, it's now tucked up and out of the way. The some of the wiring is far too long I wish they had left the ends uncrimped so I could cut them to length.
https://i.imgur.com/ayZKxKSl.jpg
island dormy
- Drag Link
Hay Colin
I would not take advice from those dormobile owners they are usually half asleep on the job ( or about to pull over and have a nap.)
Victor
Victor
cbalme
- Slave Cylinder
Finally got a bit of painting done this weekend. I chose to paint the parts that are going inside the box with rubberized gravel-guard to give it a better finish inside the box instead of showing where I haven't completely sanded the paint to bare metal. I then coated the gravel guard in bronze green so I wouldn't have to look at any black bed liner.
Here it is before painting over top. I used a self-etching primer underneath to prep the aluminum and wiped it down with acetone.
https://i.imgur.com/K8KQAsRl.jpg
All the bits painted, I had to redo the doortops for the third time and this will be the last no matter the condition, it is getting out of hand how difficult they are to paint.
https://i.imgur.com/nR9hvlCl.jpg
Other than all these bits the tub is the last thing to paint green and then the truck cab. I am not sure how I want to paint that it'll either be completely white or only white on top with a green back. I really can't decide.
Won't be ready for the rally, maybe Brits on the Beach?
cbalme
- Slave Cylinder
Installed some new headlights to replace the old lights I found in the barn. They're a lot brighter that's for sure!
https://i.imgur.com/wUt0k2Fl.jpg
Last night I turned my attention to the dashboard, I started by installing the warning lights, for the most part they fit pretty good but are slightly loose.
https://i.imgur.com/0jlnDlll.jpg
Then I got the inspection lamp socket installed. Bit of a pain because they are hard to grab onto and turn at the same time while holding the dash.
https://i.imgur.com/rKUZA3Ml.jpg
Didn't get a chance to take many photos of the install but here is the finished product, just needs to be wired and then it can go on the bulkhead! Very pleased with how it looks.
https://i.imgur.com/KsdkWSOl.jpg
I also mounted the dual gauge which was a bit of a pain with the capillary tube, I was very stressed about kinking it but it turned out fine.
https://i.imgur.com/rIMBiHll.jpg
I also need to find one bulb for the dash. The rest I tested and work fine. Are they available locally or do I need to order a few spares in?
Hi Colin,
A very valiant attempt to have her ready for the Rally in the Valley! So close ... but yet so far!
No worries, all good things are worth waiting for.
She's looking great, almost there!
cbalme
- Slave Cylinder
So close yet so far! The little jobs seem to be neverending on this project. I have been chipping away at a few of them over the past weeks.
I got the rear tub ready for the top coat of bronze green, the bed has been primed and then coated with rubberized rocker guard. It took exactly three big cans to do the whole lot. I have about a gallon of paint left so that should be plenty.
https://i.imgur.com/zPguH7zl.jpg https://i.imgur.com/MvvpiQAl.jpg
Check rods have been recoated and reinstalled.
https://i.imgur.com/21M8YeAl.jpg
Also adjusted the steering box and the self-cancelling turn signals, which work perfectly although one day I'd like to replace the dry and cracked rubber wheel.
https://i.imgur.com/b8DuYBXl.jpg
The capillary gauge got tested in a mug full of hot water and works as it should.
https://i.imgur.com/wHa9gKVl.jpg
To finish off this evening I knocked off the galvanizing I'll be using on this tub, it is in alright shape but not perfect. Considering the quality of the paint job and the fact that this truck will be used for what it was originally meant for I am not too terribly concerned about the galvanizing being faultless. Eventually, If I want I can always get a spare set regalvanised and install that down the road. But to be honest, once it's installed it will most likely never come off again. I just need some good pieces that go down the sides at the back and protect the corners and a windsheild frame I have yet to source those.
https://i.imgur.com/b7v2aLel.jpg
cbalme
- Slave Cylinder
One more thing knocked off the list to paint. Very annoying to paint but I don't think I missed any spots. In the next few weeks that will get the cappings put back on and then it'll get mounted to the chassis. After that, everything should come together very quickly.
https://i.imgur.com/lQnDiRzl.jpg
Also got the 109 out into the farmyard to see the progress in the sunlight. Really puts into perspective how small this Land Rover is compared to modern trucks.
https://i.imgur.com/TvSt5a2l.jpg https://i.imgur.com/NZjjbUsl.jpg
Still debating what colour to paint the truck cab, does anyone know what it would've been originally? I am thinking either full green or full white or white top and green back. I can't seem to find a trace of green on the whole thing so I am not sure.
oldgravy
- Captain Crunch
That's looking really awesome, man. Nice work.
cbalme
- Slave Cylinder
Lately, I've had quite a lot of time off so the 109 has slowly been coming together, not long now until I'll be cruising around.
I got the frame fully welded up and ready to mount a 3 door tub instead of a station wagon tub, then I gave everything that hadn't been painted a coat of gloss black, then I gave the top frame rails a good coating of waxoyl, very easy to apply with a brush and I'm pleased with how it turned out. I'll do the rest of the truck before it goes back together.
I also coated the seatbox, floors and gearbox tunnel with sound deadening asphalt stuff, time will tell how well it works. Should at least keep some of the vibration down.
https://i.imgur.com/dfTrX0el.jpg
Began installing bits onto the tub a few days ago, it looks really good and I'm really pleased with how it turned out.
https://i.imgur.com/HYlkMgOl.jpg
Today I visited Matt down in Victoria and he gave me a crash course on hammer rivets. It's amazing how easy it is compared to pop rivets or screws. Here's the tailgate which we used for practice I'm very pleased with how it turned out and look forward to doing the tub.
https://i.imgur.com/qmC5SOrl.jpg
Almost there!
Almost there!
cbalme
- Slave Cylinder
Had a riveting experience putting the tub cappings back onto the tub. It took most of the day but the end result was well worth it, I would've been there much longer if I was pop riveting the whole tub.
I started with the front bar which took the longest since it needed so many pop rivets and required a fair bit of drilling to fit.
https://i.imgur.com/buB9xOml.jpg
Then added the siderails which went very quick with the air riveter. It's much more relaxing and comfortable not to be cranking on a hand riveter all day.
https://i.imgur.com/LMmRF49l.jpg
Here's a picture of the clecos in action they are very handy when you don't have a helper and keep everything nice and tight.
https://i.imgur.com/xs4E8bMl.jpg
I chose to install pop rivets on the gas filler but I may swap them to pop rivets someday. The pop rivets are original so should add a few points at the car shows to offset the mud splatters.
https://i.imgur.com/B6HNpOYl.jpg
All back together, just need to pop rivet the bed strips in but it can go onto the truck anytime now.
https://i.imgur.com/vAqGVDAl.jpg
You need an air pop rivet gun.
cbalme
- Slave Cylinder
Hi Red, yes I should've got one a while ago, but I am close to finishing so there's no point. I haven't got much else riveted because of crops and my hands are pretty tired.
https://i.imgur.com/eV7w3UFl.jpg
So I took a break and put the doortops back together since they were getting in the way in the old tub. Here's my sophisticated doortop stand for the time being.
https://i.imgur.com/p3PPnd1l.jpg
They look much better with the glass installed.
https://i.imgur.com/FsfJHZ5l.jpg
Really pleased with the finished product although they have a few imperfections
https://i.imgur.com/pwiNWoHl.jpg
cbalme
- Slave Cylinder
Finally got the heater installed and plumbed in, just need to wire it and then attach the cables which shouldn't be too hard. It was a bit of a struggle to make it look tidy but I managed to make it look alright in there.
https://i.imgur.com/t80tk0Al.jpg
Other than that I got the headlights wired in, I had to go buy a new dipswitch because the orignal that I thought was good turned out to be a dud but everything is installed. I've been slowly cleaning up the wiring and clamping it down so it doesn't get chaffed.
https://i.imgur.com/JIBfZmrl.jpg
https://i.imgur.com/K9D5Yvwl.jpg
This afternoon with a bit of help I got the tub installed, the paint isn't perfect but that means I won't be as worried while offroad.
https://i.imgur.com/xSm719cl.jpg
https://i.imgur.com/BjvZUz4l.jpg
Hopefully in the next few days I'll be taking it for a test drive!
Looking great Colin .... so close ... so close ....
