Left-hand drive box has broken tube piece. Was leaking but comes with a seal kit. $25
Right-hand drive box is in good used condition. $25
One right hand & one left hand defender power steering box
Forum rules
deanc5
- Wing Nut
Bern B
- Hot Manifold
Re: One right hand & one left hand defender power steering b
Interested in your left hand drive box
Bern
604 nine zero eight 2178
Bern
mel rover
- Half Shaft
well if the left-hand box is not sold I will take it 2504980157
thanks, Rob Mills
thanks, Rob Mills
deanc5
- Wing Nut
Re: One right hand & one left hand defender power steering box
I have a potential sale on the left-hand box pending a trip I plan to Vancouver in the next while. I'll repost if anything changes.
andrewMcF
- Crank Case
I'm interested in your right hand steering box. What bolt pattern is it? I have a 1991 ex-MOD with a 300tdi in it, the 300tdi engine needs the power steering pump but the truck doesn't have a power steering box! I just blocked the lines from the pump, removed the paddles and packed it full of grease... TaDo idler pulley! lol But if I can put a power steering box in that'd be great!
