LR3 build
SMohan
- Newbie
LR3 build
I've acquired a used 2005 LR3. It's a Java Black SE V8 with a black interior.
I've got all the past service records and it was well taken care of mechanically. I got a good deal on it, because more recently it sat un-used for an extended period of time. There's a bunch of interior trim pieces that are broken / missing. There's a rather large dent in the rear pillar from backing into a structure in a parking garage. The roof glass has a long crack across it. The back up sensors need attention. There's an SRS airbag light on the dash: probably from a plug or wire under the drivers seat when I moved the seat back.
The plan is to start with all the fluids and maintenance requirements. The first purchase will be a IId Scan tool. LCA's and sway bar bushings need doing. The alternator needs replacing. On the Disco3-UK website I found a 'must do checklist for new LR3 owners' that I'll slowly pick my way through too.
Once I get ahold of the big maintenance issues, I'm planning a build with a slant towards an overlanding / bicycle hauling / camping rig.
I'm happy to once again have a Land Rover, and I'm looking forward to meeting some Rover-Lander members and joining the club.
The truck was covered inside and out in thick layers of old dust. I've put some elbow grease into it. Two days of washing and cleaning later... :shock: It was fun and satisfying to see what a gem was under all that dirt, and at the same time I got a good glimpse into what's broken and in need of attention on the truck.
I've cleaned inside the engine bay, cleared the sunroof drains, defogged the headlights, and fixed some interior fittings (glovebox latch, sagging headliner, power seat controls).
- (89.83 KiB) Downloaded 3922 times
BlkP38
- Bumper Sticker
Re: LR3 build
Stephen,
Could not see the images, but maybe that's just me.
Anyway, there are a few of us on the big island that get together for excursions. Right now I think many of the backroad routes are closed due to fire closures, but keep an eye on Vancouver Island Events.
I am in Maple Bay if you are passing.
Eric.
Eric.
SMohan
- Newbie
Re: LR3 build
I'll learn how to properly submit images at some point in the future.
SMohan
- Newbie
Re: LR3 build
I've been slowly picking away at the 3.
Jobs done include: inspecting various plugs to clear the airbag light on the dash, solder repair the heated driver's seat element (nice to have heated seats again!), LCA's (with Polybushes) & rear sway bar bushings (thanks to Rovalution for those two fixes), hood latch repair, custom receiver for a rear bike rack, reflective close cell foam window inserts (for stealth camping), ashtray/coin tray fix, glove box fix, blower door lubed to remove farting noise, and diagnosed a bad parking sensor.
I need to buy a IID Scan tool soon.
I'm liking the truck very much.
- (115.15 KiB) Downloaded 3921 times
SMohan
- Newbie
Re: LR3 build
With the recent repairs done (sway bars and LCA's) I had planned to tag along on tomorrow's Vancouver Island trek.
Unfortunately, I was driving down a gravel road yesterday and the rear window exploded into a thousand pieces. This was in Comox during the snow storm so when I parked to clear some of the wreckage the back of the truck was quickly filled with blowing snow. Crazy! I jury rigged a temporary plywood cover. Monday it goes in for a new piece of glass.
Maybe I'll make the next Vancouver Island event? :roll:
- (111.73 KiB) Downloaded 3922 times
SMohan
- Newbie
Re: LR3 build
I got my rear glass replaced. Thankfully I had a good deductible, as it sure was pricey! Looks like I need a new rear wiper arm because now the blade doesn't contact the glass on it's arc.
This week I built a sleeping platform in the back. Both sections are removable. When the front section is out, the middle row of seats can be raised and the back section fits nicely against them. I used 3/4" birch ply, indoor/outdoor carpet, and pre-drilled steel 'L' brackets from Home Depot. I'm happy with how it turned out. I recently took a ferry trip and fell asleep back there in comfort!
I've also mounted the GPS from my motorcycle into the empty hole in the middle of the 3's dash. It's an unobtrusive mount, and will easily move back and forth from my bike to the 3.
My buddy welded up a hitch receiver for me. Now I can put my bicycle rack on the back. I've also got a Yakima set of bars on the roof now. I'm hoping to find a cargo box to go up there.
This is all in anticipation of a trip south to Arizona over Christmas. I'm pretty excited about that!
Mostly importantly: I got my ROVERLANDERS decal on the 3.
- (75.29 KiB) Downloaded 3921 times
SMohan
- Newbie
Re: LR3 build
I'm hoping I have this photo issue sorted now?scraig wrote:Is it just me or are the pictures not coming through?
TimberPig
- Bumper Sticker
Re: LR3 build
They're coming through fine for me, so likely a settings issue if they're not working for others.Mohan wrote:I'm hoping I have this photo issue sorted now?scraig wrote:Is it just me or are the pictures not coming through?
cbalme
- Slave Cylinder
Re: LR3 build
I can see them now, I couldn't before.
Nice LR3, will hopefully see you on the next run. (No Idea when that is.)
If only I could convince my Mum to let me convert the back of the LR3 into a camper...
SMohan
- Newbie
Re: LR3 build
I've built it in a way that doesn't cut, damage or change the interior. I can take the whole thing out in 3 minutes. Turnbuckles hold it down to the existing cargo points. It cost me about $300 in the end. I can take more detailed photos of the framing if someone wants to copy it.cbalme wrote:
I'm thinking I can also take out the third row seating to gain a bit more storage space on longer trips if needed. Here are some shots of the middle section removed, the mid-row seats up, and the storage space beneath them:
- (48.6 KiB) Downloaded 3848 times
- (116.33 KiB) Downloaded 3849 times
- (87.09 KiB) Downloaded 3849 times
SMohan
- Newbie
Re: LR3 build
There was a thick hazy ring inside my left headlight that has bothered me for awhile, so I took it out to discover that one of the access ports on the back of the light was undone. It must have been improperly done up during a bulb change. Moisture and critters were entering thru there.
There was all sorts of stuff rattling inside it, so I took it apart to clean it out and clear the lens.
Since I had to open it anyways, I did the headlight 'de-tango' mod:
https://www.disco3.co.uk/forum/headlamp ... 553f8b4d2d
Well,actually it is only a partial detango. My exception was I kept the side marker/reflector and a portion of the orange over the turn signal - because of NAS / US regulations and laws and all that... :roll:
I like the slightly 'modernized' look that leans towards an LR4. Probably wouldn't have bothered if I didn't have to open the light anyways. Just gotta do the other light now.
- (104.06 KiB) Downloaded 3848 times
- (58.1 KiB) Downloaded 3849 times
SMohan
- Newbie
Re: LR3 build
I'm happy to report that my 3 is getting lots of use and finally getting dirty!
I attended my first Rover-landers run this weekend, spending the day exploring the Chemainus River Provincial Park area with a great group of folks. It was a good day. I’m already looking forward to the next run. Over Christmas we escaped south in the 3 to Arizona, New Mexico, and California with our bicycles strapped to the rig for some cycling in warmer climates. The truck performed flawlessly and was very comfortable to sleep & live in.
There seems to be a never-ending list going on the 3, but at least the ‘needs’ are getting dealt with and checked off before the ‘wants’. We treated ourselves to a Christmas present of a propane-fueled campfire ring. That made a huge difference in wanting to spend the evenings outside in areas where open fires were not permitted. I’ve finally got a iid scantool on the way in the mail, I’ve started putting together a list of essential spares and tools to stay in the truck, and I’m looking into a handheld radio for future outings with Rover-landers.
Future trips/runs on the horizon:
Founders Day sounds like fun.
Moab in May.
Vancouver island Roverlanders camp-out in June?
Moab in May.
oldgravy
- Captain Crunch
Re: LR3 build
That looks really sharp! Nice work on the sleeping platform.
rgallant
Re: LR3 build
Nice job on the sleeping platform, I plan on converting the one I use in my D2 to something similar
SMohan
- Newbie
Re: LR3 build
rgallant wrote:Nice job on the sleeping platform, I plan on converting the one I use in my D2 to something similar
Thanks! I'm quite pleased with it. I don't think there's much I'd change on it now that I've used it on a few trips.oldgravy wrote:That looks really sharp! Nice work on the sleeping platform.
I'm planning on attending the Founder's Day event, so if you want to see it in use... I'll be sleeping on it friday night :)
I recently found a deal on a GAP iid scan tool. I've got that up and running now. I've changed all the fluids under the truck, rebuilt the alternator, changed the LCA's, and have started a stash of essential spares (brake light switch, rear brake bulbs, etc.,etc.,).
I'm feeling like I'm on top of the maintenance now. I'm still having issues with moisture inside one of the headlights, so I'll tear that apart again soon. This time I plan on doing the full 'detango' on them with the chromed amber turn signal bulbs mod.
Oh - and for some unknown reason I decided to take the 3 to a truck wash yesterday in minus 5. :roll: I haven't washed it since well before my road trip south. Lotsa road salt on it. Nice to see the shiny black paint again, plus a few new 'BC racing stripes' from the last Roverlanders run. :)
I'm still really enjoying it all!
SMohan
- Newbie
Re: LR3 build
I finished the de-tango on the headlights today. I'm just waiting for the chromed-orange turn signal bulbs to arrive in the post.
I also got to work with the GAP tool today. I flashed some ECU's and played around with suspension heights. Very neat tool to have.
I bought an A-Protection bar off another Roverlander's member. It's missing the hardware though, so I've had to fabricate my own.
- Stephen
- Stephen
SMohan
- Newbie
Re: LR3 build
I measured and drilled the holes for the A-bar today. My DIY/home-made mounting brackets lined up nicely with the pre-existing threaded holes in the metal bumper framework. After the front end goes back together, the next step will be building my own mounts for securing the top of the A-bar to the truck under the hood. I plan on incorporating aux. light mounts into those mounts too.
Many thanks to Colin for welding some nuts onto the lower mounting brackets for me. They are strong and look good. :)
SMohan
- Newbie
Re: LR3 build
Bumper is installed! Yay! :D
SMohan
- Newbie
Re: LR3 build
I found a used one for sale on an LR3 forum. I saved about $200. The cheapest I've seen them new are from Lucky8:scraig wrote: Where did you get a deal on the GAP iid tool?
https://www.lucky8llc.com/collections/d ... s-12/t-lr3
Mines the bluetooth version, so I can operate it from an iphone.
I've flashed a couple of the ECU's with software that is included with the tool. A couple neat updates were:
- 3-flash turn signals (allows you too lightly touch the turn signal stalk for 3 flashes when passing)
- A clock placed in the middle of the instrument display
I also like the ability to play with the car configuration files to customize features and turn systems on or off.
I diagnosed a couple fault codes as well. GAP works with Bell Auto Services. You can input any fault code on their website and it'll translate it for you:
https://bellautoservices.co.uk/diagnostic-services/
I also bought a transmission flash from GAP that's not included with the tool. It modifies the shifting algorithms. It takes a couple cycles of driving for the changes to take effect, but already the shifting seems a bit smoother and has removed the 'thunk' it had when I put the pedal down from a rolling stop.
And I've been playing with the suspension heights a little. I've set the 'standard' height stance an inch higher, and added a slight forward rake. I could add another 3/4" to 1" yet, but then my current tires look a little small under the rig. :lol: Once these tires are done I'll look into some 265/65 R18 KO2's. Folks on this forum have recommended Cedar Tire, so I'll go there when the time comes.
SMohan
- Newbie
Re: LR3 build
I've made a start into wiring some off-road lights to the A-bar.
I bought an oem factory switch from another local R-L member.
I made a template and cut into the dash where other LR3's have this switch mounted. It went smooth and I'm happy with the install.
I found a wiring diagram on an LR3 forum that uses the oem factory switch.
The actual lights I have are cheap aftermarket affairs. I'll upgrade someday when I find some better ones.
SMohan
- Newbie
Re: LR3 build
Offroad lights install complete!
:D
:D
