1963 IIa V8 Race Rover
John Boy
Re: 1963 IIa V8 Race Rover
So, yes I bought the 1955 rover 88, series 2 from a member of this forum. Fear not, for I do respect the rovers. So, I will be swapping some of my worn bits with the better bits of this series 2. In the end the series 2 will still be hole, with additional parts from my 2a to boot. So for any member interested in salvaging the series 2, in time this can be done. I will start posting photos soon to.
Cheers all.
Cheers all.
John Boy
So, here are a couple of 1959 Rover 2 photos, I boobed and called it a 1955, my bad.
- (142.14 KiB) Downloaded 6833 times
- (125.33 KiB) Downloaded 6834 times
John Boy
Ahh the steering box, the unmovable British work of wonder that I read so much about on this forum. I spent all of five minutes looking at the problem, then used my cutting wheel to remove the unit. Don't hate on me for doing it this way, I saved the insides and have a spare sleeve to install into. So for the future, I have a working steering box thing that can be installed if needed.
- (133.27 KiB) Downloaded 6834 times
- (75.12 KiB) Downloaded 6833 times
John Boy
Finally patched up the front of the frame, and will modify the front bumper to use the bolts from a side position instead of the top down way the Rover once used.
- (115.86 KiB) Downloaded 6833 times
- (113.89 KiB) Downloaded 6833 times
- (101.06 KiB) Downloaded 6833 times
John Boy
A splash of short strand fibre glass and presto, all good now. Also a look at how roughly the P38 power steering box will fit.
- (129.88 KiB) Downloaded 6833 times
John Boy
All four mounts finally welded in place after an eternity of fine tuning. As you can see, I have generally got 18 inches of motor height from the top of the frame where the radiator once sat. I checked with the 1959 rover and it has generally 19 inches of height, So the hood should close with 1 inch of room to spare, just don't let the motor mounts fail.... :wink:
- (126.09 KiB) Downloaded 7095 times
- (84.58 KiB) Downloaded 7096 times
- (112.48 KiB) Downloaded 7096 times
John Boy
So.... Who's your Daddy? That's right, me... I have been trying desperately to reuse and keep as much of the original Rover as possible for any future possibility that this unit might be returned to its original condition. To that end, I was disappointed to have to use the D1 cross members on the original rover, that was until now :D In the following photos, I managed to reuse the original cross members though not in there original positions, but still there none the less.
- (115.7 KiB) Downloaded 7077 times
- (130.81 KiB) Downloaded 7077 times
- (134.56 KiB) Downloaded 7078 times
John Boy
The exhaust system will be a bit of a challenge as I want to keep it as high into the frame as possible. This will secure good ground clearance.
- (98.14 KiB) Downloaded 7077 times
- (122.44 KiB) Downloaded 7078 times
- (112.52 KiB) Downloaded 7078 times
John Boy
The original exhaust headers will also allow for the starter motor to fit with little difficulty.
So your probably asking yourself, Ya... but John, what happens if you need to drop the transmission? That's easy actually, there is clearance still to pull the block straight up, the bell housing gets pulled off, then the whole transmission can be pulled straight out while resting on the cross members. But hey... I build things never to fail, and so never need to be removed... :lol:
John Boy
So, I got to thinking. I have room I think to reuse the discovery 1 power steering box, but it comes with pro's and cons. The P38 puts the control arm ahead of the front diff, but the D1 puts the nut for the control arm over the diff.
- (107.18 KiB) Downloaded 7059 times
- (138.32 KiB) Downloaded 7060 times
- (145.24 KiB) Downloaded 7060 times
John Boy
The pro's are that it is a cleaner fit, and allows for the possible reuse of the original rad from the D1. Cons are the bump stop problem, with two solutions. One; place the diffs on the bottom of the leaf springs, this screws with the drive shaft geometry, but not terribly. Two; use a stiff shock to prevent the bump stop from impact, like a heavy duty shock or air shock.
- (141.36 KiB) Downloaded 7045 times
John Boy
I think for my purposes of a race truck, option two is best. A stiff ride is good for cornering and racing, this also allows for minimal impact to keep the rover traditional. Longer bump stops might also be needed to insure the steering is never impacted.
- (94.65 KiB) Downloaded 7045 times
- (119.74 KiB) Downloaded 7045 times
- (111.14 KiB) Downloaded 7045 times
John Boy
This will also mean cutting into the rover fender wings, but that can be done on a minimum impact.
- (117.75 KiB) Downloaded 7046 times
- (77.16 KiB) Downloaded 7045 times
- (106.15 KiB) Downloaded 7046 times
John Boy
one can see that the wings come almost flush to the frame, and so does the D1 rad. Then there is also the idea of power breaks or just stock man power breaks.
- (119.63 KiB) Downloaded 7045 times
- (92.16 KiB) Downloaded 7045 times
John Boy
Just a note on stanz, the D1 diffs are wider, as are the aluminium rims. Good for racing, bad for appearance. With the stock white rims, the tires come flush with the outside of the wings, rather then recessed like stock. Gauge from the bulk head holder thingie doma hicky on the original and mine.
- (122.4 KiB) Downloaded 7045 times
- (149.75 KiB) Downloaded 7044 times
John Boy
There is also the option of longer shackles, this might be needed, but only if I'm desperate. Want a low profile for racing, not a tall one :twisted: :twisted:
John Boy
Dropped the bulkhead on the frame today for a look, and thanks to the excessive measurements, the fit is very nice. The only tight spot is the passengers exhaust manifold, but it only needs a bit of fudging to make work. The severe gap on the back side, between the block and bulkhead will house the electrical parts for the 3.9 GEM, placed on a tray.
- (130.51 KiB) Downloaded 7057 times
- (131.92 KiB) Downloaded 7057 times
- (138.8 KiB) Downloaded 7057 times
John Boy
The transmission tunnel will be customised to hold the auto shifter and high/low shifter.
- (130.64 KiB) Downloaded 7057 times
John Boy
The block does sit low in the frame, and gives good clearance all the way around. The sides of the block also give adequate clearances.
- (151.18 KiB) Downloaded 7058 times
- (142.7 KiB) Downloaded 7057 times
- (126.97 KiB) Downloaded 7058 times
Tony4921
Hi, do you still need that driveshaft manufacturing?
John Boy
yes tony, I do. Still just working out the differential angles to be sure, but soon, very soon. :)
John Boy
Well, after forever, loading the frame to compress the ride height and then unloading the frame to produce differentials and tires leaving the pavement, I finally have a midpoint geometry for the drive shafts. This is a race truck, so the need for the differential travel is not dramatic as in off-roading, but more for compression in tight corners and under acceleration and deceleration loads. I have today given the two shafts to Tony to be modified and balanced, and wait with baited breath for the return. In the mean time, the bulk head is under repairs and almost ready for paint. soon the body will be reunited with the frame and then the real hard work begins, electrical. I hate electrical.
StuartL
- Horn Blower
That is Peter, both he and his Rover live in Victoria now :)
Tony4921
Hello John, how is the Rover build going?
John Boy
hey Tony; Things are good, been busy with house project and family issues. The build proceeds well, and I should post photos soon. Typical put the parts on, check fit, remove the parts, paint, reinstall parts, check fit, remove, etc. Cheers mate
