D90 Rebuild......
99Disco2
Re: D90 Rebuild......
#51 Post by 99Disco2 » Sat Aug 17, 2013 5:20 pm
Thanks... am running a RaRo ZF4-HP22 so it's all manual shift. If you want to keep the HP24 the guys back in the UK use Compushift... http://www.hgmelectronics.com/products- ... mpushiftii
Search on the D44 board, think there were some threads on there about using & setting it up.[/quote]
Thanks for the Compushift link,I will do some research on it.
As for yours, I take that it is a Range Rover ZF4 right?
What year is it from and how did you get it to run manual shift?
My wife wants to keep the auto box but doesn't mind shifting it her self, I would rather have a R3380 or LT77 instead.
Chris
LandyAndy
Maxi Drive
#52 Post by LandyAndy » Sat Aug 17, 2013 8:17 pm
99Disco2 wrote:As for yours, I take that it is a Range Rover ZF4 right?
Yep, came out a RaRo years ago... haven't a clue what yr though... and manual shift as in... it don't need a computer to make it work like the HP24 :wink:
99Disco2
#53 Post by 99Disco2 » Sat Aug 17, 2013 10:04 pm
Ah got it now, sorry I had a brain lapse there
My current tranny (HP24) is fully electonic and yours the HP22 is full maual like an old school Chevy Turbo 350, correct?
Now wasn't the HP22 used in the D1's as well?
Oh and the HP24's tourque converter won't fit in the HP22 right?
I was reading on "Paddock Spares" web site and they state the bell housings are different and not interchangable, what engine block are you running?
Sorry for bonbarding you with questions
Thanks also for your help
mojigglins
#54 Post by mojigglins » Fri Aug 23, 2013 9:27 pm
Wow!! Amazing! Build!
I was just wondering what t-case are you running and gear ratio, LT230 1.667?
Thanks for sharing!!
LandyAndy
Maxi Drive
#55 Post by LandyAndy » Fri Aug 23, 2013 10:12 pm
mojigglins wrote:Wow!! Amazing! Build!
Yup, with std diffs... Same as D44 run in their trucks. About the ideal ratio for 35's ;)
LandyAndy
Maxi Drive
#56 Post by LandyAndy » Sat Dec 14, 2013 12:23 pm
Not a lot of progress these past weeks, but did pick up a new alum rad whilst I was back in the UK... saved a bunch on tax & shipping :D
http://i946.photobucket.com/albums/ad30 ... 86eb55.jpg
http://i946.photobucket.com/albums/ad30 ... 82437d.jpg
As funds are a bit thin on the ground at present made a start on the custom dash, decided to use the Vintage Air A/C unit as I already had it (was going to use the OEM heater & mod it) & they get good reviews. So, made up a small cradle from 3/4" 100 wall tube & some strip stock to mount the A/C unit just off centre on the bulkhead.
http://i946.photobucket.com/albums/ad30 ... 1fc0db.jpg
http://i946.photobucket.com/albums/ad30 ... 5fd8ab.jpg
Will be keeping the dash top crash pad & the RHD instrument binnacle as it'll mount easily onto the dash front and why reinvent the wheel. Next to source some round facia vents & defrost ducts so I can lay the dash out, have already got the Carling switches and a 6 way mounting bracket for them also. Was thinking that the switches should go above the A/C unit as that space will become quite full once all the ducting is attached. Not sure about where there will be space for a radio... mine is actually mounted into the Laselle headlining but if anyone else wanted one it'd need to find a home in the dash..... ummm.... need to get the thinking cap on for that one :wink:
LandyAndy
Maxi Drive
#57 Post by LandyAndy » Sun Mar 23, 2014 9:52 am
Been a while since last update...... have spent many hours on the CAD getting the bulkhead & top crash pad models correct and the dash drawn up. Decided not to use any LHD dash parts in the build at all and just use what I had, any other LR parts needed are easily available on Ebay or the usual LR suppliers. Here is the model to date.
http://i946.photobucket.com/albums/ad30 ... 92947f.jpg
After getting just the ends cut, adjusted & fitted the bulkhead model needed a few tweeks, then I finalized the main dash panel and made a cardboard mock up. A few more adjustments to the locations of switches etc and then off it went for cutting.
http://i946.photobucket.com/albums/ad30 ... db61c5.jpg
Now here is the drivers side tacked up and in place. Will make some final adjustments to the model but nothing that means a recut of this part. :D
http://i946.photobucket.com/albums/ad30 ... 9de362.jpg
http://i946.photobucket.com/albums/ad30 ... 02047b.jpg
http://i946.photobucket.com/albums/ad30 ... aaa78a.jpg
The old heater control levers have been repurposed to open & close the bulkhead vent flaps using heater control cables and some custom brackets. I've added a side window vent for defrosting & 12v/USB charging points for phones etc. Now just waiting on hinges/catch for the passenger side glove box from Southco dealer and a D1 interior grab handle too. I can then get the passenger side finished off as the main panel is the same profile as the drivers side. After that I can focus on the centre section that covers the HVAC unit & the top pod that'll wrap up & over the top pad where the old ashtray was.
LandyAndy
Maxi Drive
#58 Post by LandyAndy » Mon Dec 29, 2014 1:56 pm
Haven't updated this in a while, so here are a few more pics :
LED lights for the rear cargo area.
http://i946.photobucket.com/albums/ad30 ... 219e1b.jpg
LED lights to see where I'm going :D
http://i946.photobucket.com/albums/ad30 ... 5f0bb5.jpg
Limb riser tabs & couple more brackets for LED ditch lights.
http://i946.photobucket.com/albums/ad30 ... 0de12e.jpg
Got a bought a pair of new seats in the sales.
http://i946.photobucket.com/albums/ad30 ... 075398.jpg
Will use the Qt f/g seat mount.
http://i946.photobucket.com/albums/ad30 ... 21ae66.jpg
With some adaptor brackets to make them easy removable.
http://i946.photobucket.com/albums/ad30 ... e9a61e.jpg
LandyAndy
Maxi Drive
#59 Post by LandyAndy » Mon Dec 29, 2014 2:06 pm
Decided to make long term servicing easier up here in the sticks..... so, out came the old RaRo motor !
http://i946.photobucket.com/albums/ad30 ... 6a41e1.jpg
And in it's place will be.... :D
http://i946.photobucket.com/albums/ad30 ... f28a78.jpg
And behind that there is a NV4500 linked to the LT230 with one of Nicks adaptors.
http://i946.photobucket.com/albums/ad30 ... 5a3a5a.jpg
I'll also be fitting a Behemoth Drivetrain Strong Box between the NV & adaptor next, that'll give me a crawl ratio of 180:1..... :bounce:
http://www.behemothdrivetrain.com/STRON ... _KITS.html
So, I have a used NP241C to donate it's guts... not bad for a pack of beer :wink:
LandyAndy
Maxi Drive
#60 Post by LandyAndy » Mon Dec 29, 2014 2:11 pm
franko
#61 Post by franko » Mon Dec 29, 2014 2:51 pm
So....you applying for Alaska off road warriors season 2 ;-)
LandyAndy
Maxi Drive
#62 Post by LandyAndy » Mon Dec 29, 2014 4:03 pm
franko wrote:So....you applying for Alaska off road warriors season 2 ;-)
I doubt it'll be finished for then... lol
99Disco2
#63 Post by 99Disco2 » Fri Jan 30, 2015 11:32 pm
[quote="LandyAndy"]Decided to make long term servicing easier up here in the sticks..... so, out came the old RaRo motor !
So the adapter you are using, was it bought locally?
I am looking at an adapter for the Dodge 23 spline NV4500/NV3550 for a diesel conversion.
LandyAndy
Maxi Drive
#64 Post by LandyAndy » Sat Jan 31, 2015 11:14 am
I got the adaptor kit from Nick over on Defendersource, as far as I know he only makes the GM 32 spline spud shafts.... Check on EBay, I think there is a Dodge adaptor sometimes listed but I don't think it has the holes in it for the mounts.
99Disco2
#65 Post by 99Disco2 » Sun Feb 01, 2015 6:06 pm
LandyAndy wrote:I got the adaptor kit from Nick over on Defendersource, as far as I know he only makes the GM 32 spline spud shafts.... Check on EBay, I think there is a Dodge adaptor sometimes listed but I don't think it has the holes in it for the mounts.
You are right about the Dodge adapter, it's from Diesel Conversion Specialist for $599.
Does Nick on Defendersource still sell the GM one's.
LandyAndy
Maxi Drive
#66 Post by LandyAndy » Mon May 04, 2015 12:20 pm
A few updated pics.....
Drive line assembled with the crawler box.
http://i946.photobucket.com/albums/ad30 ... fac8nw.jpg
Trial fit of the Goat Build PAS pump & Alt relocation brackets.
http://i946.photobucket.com/albums/ad30 ... bapmsp.jpg
Hi/Lo lever flipped round for easier cable shift hook up with the crawler box.
http://i946.photobucket.com/albums/ad30 ... zuckr0.jpg
Added the TD5 clutch pedal.
http://i946.photobucket.com/albums/ad30 ... 6xibrx.jpg
Trial fit of the Vortec to check water pump clearance to the Allisport rad.
http://i946.photobucket.com/albums/ad30 ... ppless.jpg
Might need to swap the oil pan out for a Camaro one if clearance at full bump is an issue.
http://i946.photobucket.com/albums/ad30 ... amlbk5.jpg
LandyAndy
Maxi Drive
#67 Post by LandyAndy » Mon May 04, 2015 12:21 pm
Yep... drop him a PM to reserve, he has another batch in manufacturing progress I believe.
Horn Blower
#68 Post by HeadDamage » Mon May 04, 2015 1:35 pm
I forget, have you lengthened the wheel base?
LandyAndy
Maxi Drive
#69 Post by LandyAndy » Mon May 04, 2015 1:49 pm
HeadDamage wrote:I forget, have you lengthened the wheel base?
Yes, to 100". Looks like if I fit a short drive shaft & carrier bearing off the 3 link x-member, I'll be able to have the same length drive shaft to the axles front & rear.
LandyAndy
Maxi Drive
#70 Post by LandyAndy » Thu May 07, 2015 11:37 pm
TOLON
#71 Post by TOLON » Fri May 08, 2015 5:26 pm
Nice! Will have to stop in for a looksee...I'll bring beer!
LandyAndy
Maxi Drive
#72 Post by LandyAndy » Wed Jul 01, 2015 3:27 pm
A few small jobs completed, PAS pipes to the steering box.
http://i946.photobucket.com/albums/ad30 ... qmijwg.jpg
Moving the engine & drive line back an additional inch has given enough room for medium frame Spal electric fans on the Alisport rad :D
http://i946.photobucket.com/albums/ad30 ... u4i6cm.jpg
Version 1 of the GM ECU mount.... version 2 has the fuse box mounted to the rear for a lower profile.
http://i946.photobucket.com/albums/ad30 ... vre1h7.jpg
Engine loom pruned out & modified for stand alone use, just the gauge wires to add then loom up.
http://i946.photobucket.com/albums/ad30 ... tfcviq.jpg
LandyAndy
Maxi Drive
#73 Post by LandyAndy » Sun Jun 26, 2016 10:46 pm
Not been round here for a while, got a new job... working on the house... you know the score...
Anyway a few updated pic's... fuel system all plumbed up
http://i946.photobucket.com/albums/ad30 ... izsd6m.jpg
Custom schedule 40 exhaust manifolds being made
http://i946.photobucket.com/albums/ad30 ... hcnayp.jpg
Engine harness all finished
http://i946.photobucket.com/albums/ad30 ... anbljk.jpg
Front propshaft centre bearing from Rakeway in the UK to get it over the 3 link cross member
http://i946.photobucket.com/albums/ad30 ... s7hfyb.jpg
Heater fully plumbed & installed
http://i946.photobucket.com/albums/ad30 ... iu6l8e.jpg
Started a new custom wiring loom to replace the old cracked one and all new switches etc
http://i946.photobucket.com/albums/ad30 ... h49oz8.jpg
http://i946.photobucket.com/albums/ad30 ... lbreao.jpg
And the seatbox is all back in with custom removable mounts for the seats to aid in servicing & cleaning
http://i946.photobucket.com/albums/ad30 ... 6l3kmw.jpg
And finally the exo cage is all powder coated & fitted
http://i946.photobucket.com/albums/ad30 ... 7mn5cz.jpg
http://i946.photobucket.com/albums/ad30 ... tjitj2.jpg
That's about it really, been a very busy 7 months since starting my new job... hope to make a bit more progress over the next few before the snow flies !
D Andersen
#74 Post by D Andersen » Mon Jun 27, 2016 10:44 pm
What fusebox did you use? I have to replace mine on my MOD 90
#75 Post by ANDYD » Wed Jun 29, 2016 9:52 pm
Looking really good Andy, very nice work. Thanks for the update.
Bet you cant wait to get all those nooks and crannies full of gooey, mucky mud!
