smoke trail
skejam
- Newbie
smoke trail
We had to travel the connector with the 300TDi Disco 1.
After chugging along for five minutes or so around 70 K, I saw I was generating smoke. Not a whole lot, not black, but not pure white either. It looked as if I had spilled oil onto the exhaust manifold (something I've done before, but not this time), and the smoking continued until the top - about 15 Kms. It didn't occur again on that long climb once I turned south at the entrance to the Coke at Merritt. I checked trans fluid later on (while hot), but since there isn't a "full" line for testing while hot, and since I could see significant fluid on the dipstick, I figured I was safe.
Perhaps the hot motor was just burning off spilled oil, but I thought I'd check in case anyone has experienced this...
_________________
JimBob
_________________
JimBob
withabix
Re: smoke trail
I had a similar experience with the 300TDI in my Defender in exactly the same location, but in February in -25C temperatures, rather than the +35 to 40C you probably had this week.
My smoke was white though - unburnt diesel.
I did get the temp gauge well into the red zone as well - belt driven radiator fan
My guess was maybe dry air, higher altitude = inadequate combustion possibly?
Not sure what caused my temperature rise - I had a full load on board and maybe I got ice/snow blinding the radiator??
rayhyland
- Drip Dry
Re: smoke trail
When I was driving through Montana and Idaho last week I noticed we were pushing out a lot more black smoke than usual. Air filter, fuel pump etc all seemed good.
Is there any reason a 200 tdi would be pushing more black smoke in the hot weather?
Ray
Ray
skejam
- Newbie
Re: smoke trail
Re: Smoking in Idaho & Montana...
D'you suppose the altitude had anything to do with that? What about having adjusted the thingey that gives more power AND more black smoke?
Re: smoke trail
Bad tank of fuel? Are you saying it is fine now?
skejam
- Newbie
Re: smoke trail
Ya, it's fine. Stopped smoking when I reached the top of the Connecter, and the load on the engine was dramatically reduced.
- Horn Blower
Re: smoke trail
Need to be careful of exhaust gas temps when pushing it hard up mountain passes. My 200tdi exhaust got so hot pulling my Sankey over the Rogers pass, a couple of years ago, that the firewall insulation caught fire from the hot down pipe after the turbo.
- Landy Man
Re: smoke trail
Firewall insulation? What's that? :lol:
withabix
Re: smoke trail
Birds nests and dead mice?Bill E. wrote:Firewall insulation? What's that? :lol:
Re: smoke trail
Range Rover. Quiet and comfortable.Bill E. wrote:Firewall insulation? What's that? :lol:
