:? Just did the points, condensor, rotor and checked the timing. All seemed well. Took the airportable for a long spin and was quite pleased with the performance as the old set of points were in a bad way. One small problem. I was doing about 50 mph and when I started slowing down(read foot off accelerator) I got a resounding backfire. This is the only time it did it. It does not pink going up a steep hill bogged down. The motor accelerates well and so on. Any ideas what this might be?
Derek
'82 Airportable.
Backfiring
rick.m
back fire.
Derek. can you call my cell wed as i am in nanaimo tues pm on the way to victoria wed night, 604-309-1877. thanks, rick.m
derek n
same as post
Thanks for the tip. Got a chance to inspect the exhaust tonight, low and behold a nice quarter in. hole hidden between the muffler and flange, a pipe approx 1 inch long. Did the quick fix tonight. will come up with something more permanent later. What a difference it has made in the noise level inside the vehicle. This hole has been there since I bought the vehicle 3 years ago. I just thought it was supposed to sound that way. So no more back fire, alot quieter and some answers on other previous woes.
Rick
I will call you Wed afternoon as I am off at 1330 hrs.
Derek :wink:
Rick
Derek :wink:
