Driver's window fell into door -- Disco2
davran
#1 Post by davran » Wed Jul 03, 2013 11:18 am
The driver's window fell into the door of the D2.
The motor seemed to be working fine; is this more likely to be the regulator, or which part is usually at fault? Lordco only lists the motor with gear on it.
Tanks,
Re: Driver's window fell into door -- Disco2
#2 Post by red90 » Wed Jul 03, 2013 3:32 pm
Yes, probably the regulator. They are not expensive.
exmod90
Half Shaft
#3 Post by exmod90 » Thu Jul 04, 2013 8:01 am
i had to replace both the driver side and passenger side regulators in the last 3 years . if you buy original LR replacements , they are expensive > 200.00 each plus tax .
davran
#4 Post by davran » Thu Jul 04, 2013 10:10 am
From where is a good place to order a regulator?
#5 Post by red90 » Thu Jul 04, 2013 10:50 am
You should be able to get them locally.
http://www.autopartsway.ca/PartList.cfm ... enum1/tabS
davran
#6 Post by davran » Thu Aug 15, 2013 1:50 pm
I have the regulator now from autopartsway, and have been searching the internet for replacement information. Are there any tricks I need to know about?
davran
#7 Post by davran » Sun Sep 01, 2013 12:47 am
Installation took about 3/4 hour, and window works now.
